BT.com
Wishlist
DYMO LabelWriter 450 Duo Mono Direct Thermal Label Printer
DYMO LabelWriter 450 Duo Mono...
£150.15
Hurry, only 1 left in stock!
£150.15
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Print the widest variety of DYMO labels with one versatile printer. With the ability to print paper and permanent D1 plastic labels, you're ready to tackle virtually any labeling job. Connect a DYMO LabelWriter label printer to your PC or MAC and you're ready to print address labels, file folder labels, name badges and much more. LabelWriter label printers make it easy to get first-class results. Thermal printing technology eliminates the cost of ink and toner and the hassle of sheet labels, forever. Improved resolution graphics mode delivers crystal Clear text, graphics and barcodes. Sleep mode conserves energy. Put it anywhere - its compact design fits in to any modern workspace.
DYMO LabelWriter 450 Duo - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
Max Media Size
Roll (6.2 cm)
Max Media Size (Custom)
62 mm
Print Speed
Up to 71 labels/min - B/W
Max Resolution (B&W)
600 x 300 dpi
USB
Media Type
Labels, thermal paper, plastic tape
Compatible Tapes
D1 tape
Microsoft Windows XP, Apple MacOS X 10.4 or later, Microsoft Windows Vista (32/64 bits)
12.7 cm x 19.7 cm x 18.4 cm
Printer Type
Printer
Print Speed
Wired
USB
600 x 300 dpi
Media Handling
Media Type
Compatible Tapes
D1 tape
Max Media Size
Roll (6.2 cm)
62 mm
Media Sizes
Roll (5.4 cm), Roll (2.4 cm), Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (1.9 cm), Roll (3.8 cm), Roll (3.6cm), Roll (5.1cm), Roll (3.2 cm), Roll (2.5 cm), Roll (6.2 cm), Roll (2.8 cm), Roll (5.9 cm)
Max Printing Width
56 mm
1 x USB
Cleaning kit
1 x USB cable
Power adapter - external
Software Included
DYMO Label Software 8
12.7 cm
19.7 cm
18.4 cm
Accessories
£15.25
DYMO LabelWrtier Standard Address Labels
Quicklinx: 2ZCB | In Stock
£8.25
Scroll to top
