BT.com
Wishlist
DYMO LabelMANAGER PnP Mono Thermal Transfer Labelmaker
DYMO LabelMANAGER PnP Mono Thermal...
£45.03
3 in stock
£45.03
Add to wishlist
Delivery
Standard 3-5 working days
Finally, printing a label is fast and easy! With the DYMO LabelManager PnP Label Maker there's no software to install - just plug in to your PC or MAC and create great-looking labels as fast as you can type.
DYMO LabelMANAGER PnP - labelmaker - monochrome - thermal transfer
Printer Type
Labelmaker - thermal transfer - monochrome
329 g
Max Media Size
Roll (1.2 cm)
Max Media Size (Custom)
12 mm
Max Resolution (B&W)
180 dpi
USB
Media Type
Self-adhesive label tape
Compatible Tapes
D1 tape
Lithium Ion
Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7
13.6 cm x 14.2 cm x 5.3 cm
Printer Type
Printer
Built-in Devices
Cutter
Wired
USB
180 dpi
Media Handling
Media Type
Compatible Tapes
D1 tape
Max Media Size
Roll (1.2 cm)
12 mm
Media Sizes
Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm)
Media Feeders
1 x manual - 1 roll - Roll (1.2 cm)
1 x USB
1 x USB cable
Consumables Included
1 x tape cassette
Lithium Ion
Software Included
DYMO Label Software 8
13.6 cm
14.2 cm
5.3 cm
329 g
Accessories
DYMO D1 9mm Tape - Black on Yellow
Quicklinx: 5HP0 | In Stock
£11.08
Scroll to top
