BT.com
Wishlist
Duracell Replacement Samsung Galaxy S3 smartphone battery
Duracell Replacement Samsung Galaxy...
£12.49
1 in stock
£12.49
Add to wishlist
Delivery
Standard 3-5 working days
Marketing description is not available.
Duracell cellular phone battery - Li-Ion
Cellular phone battery
6.2 cm x 5 cm x 0.5 cm
38 g
Lithium Ion - 2100 mAh
3 years warranty
Samsung Galaxy S III
6.2 cm
5 cm
0.5 cm
38 g
Lithium Ion
Voltage Provided
3.7 V
2100 mAh
Limited warranty - 3 years
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been used and shows signs of use
Ref: BVCD 035536
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£7.26
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
