BT.com
Wishlist
Drobo DR-B810N-5A31 8bay B810n NAS Storage Array
Drobo DR-B810N-5A31 8bay B810n NAS...
£1,568.19
Hurry, only 1 left in stock!
£1,568.19
Add to wishlist
Delivery
Standard 1-3 working days
The B810n is a fusion of large and fast. It can present itself as a single large pool of storage. If you add two SSDs, it accelerates access to commonly used "hot" data. Ideal for a network of many users, the Drobo B810n can store and share files. Use it as your primary storage for important files and documents OR as a place to backup files, projects, or even connect computers on the network.
Drobo B810n - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
Max Supported Capacity
80 TB
0 (installed) / 8 (max)
30.91 cm x 35.81 cm x 13.87 cm
Storage Controller
SATA SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Apple MacOS X 10.8 or later, Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
NAS server
Host Connectivity
Gigabit Ethernet
0 GB
80 TB
30.91 cm
35.81 cm
13.87 cm
Built-in Devices
Led panel
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Network Services Compatibility
Microsoft CIFS, Server Message Block (SMB), Apple File Protocol (AFP)
Jumbo Frames support
Expansion Bays
8 (total) / 8 (free) x hot-swap - 2.5"
2 x Ethernet 1000Base-T - RJ-45
2 x network cable - 1.8 m
BeyondRAID technology, built-in cooling fan
UL, TUV, cUL, CISPR 22, CB, ICES-003 Class B, MIC, AS/NZS 3548, RoHS, WEEE, BSMI CNS 13438, FCC Part 15 A, ACA, REACH, VCCI V-3
X internal power supply
82 Watt
10 °C
35 °C
5 - 80%
Sound Emission
30.4 dB
Other bundles
£1,568.19
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.22
£1,571.41
Scroll to top
