BT.com
Wishlist
Drobo B1200i 12-bay SAN storage array
Delivery
Standard Due date unavailable
Drobo, makers of the award-winning data storage products for businesses and professionals, offers a line of sophisticated yet easy-to-use and affordable storage solutions for small and medium businesses. Built on the proven BeyondRAID technology, Drobo delivers advanced capabilities such as thin provisioning and dual drive redundancy, usually reserved for more expensive enterprise solutions. Drobo SAN storage for business is designed to provide reliable and high performance storage to servers running business-critical applications such as back up, email, and server virtualization. Drobo B1200i connects seamlessly to your existing TCP/IP network and utilizes the industry-standard iSCSI protocol to provide simple, consolidated storage for your servers.
Drobo SAN for Business B1200i - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 3U
Gigabit Ethernet
Host Channels
3
Maximum LUNs
255
12 (max)
Supported Drives
SATA-600 / SAS-2
Built-in Devices
Led panel
Storage Controller
SAS-2 (SATA 6Gb/s / SAS 6Gb/s)
Hard Drive
No HDD
Microsoft Windows Vista (32/64 bits) SP1, Apple MacOS X 10.5.8 or later, Microsoft Windows 7 (32/64 bits) SP1, Microsoft Windows Server 2008 R2 x64 Edition SP1, Apple MacOS X Server 10.5.8 or later, Microsoft Windows Server 2003 R2 (32/64-bits) SP1, Microsoft Windows XP (32/64 bits) SP1
AC 120/230 V - 50/60 Hz
Power Redundancy
43.61 cm x 55.5 cm x 13.21 cm
21.3 kg
Hard drive array
Enclosure Type
Rack-mountable - 3U
Chassis
Built-in Devices
Led panel
Supported Devices / Modules Qty
12
Supported Drives
SATA-600 / SAS-2
Storage
HDD Array External Interface
Gigabit Ethernet
Host Channels
3
Maximum LUNs
255
Storage Controller
SAS-2
Channel Qty
12
Interface Type
Data Transfer Rate
600 MBps
Max Storage Devices Qty
12
Hard Drive
No HDD
Expansion Bays
12 (total) / 12 (free) x hot-swap - 3.5"
3 x Ethernet 1000Base-T - RJ-45 , 1 x Ethernet 1000Base-T (management) - RJ-45
Software Included
Drobo Dashboard
UL, TUV, CISPR 22 Class B, cUL, CB, ICES-003 Class B, MIC, AS/NZS 3548, RoHS, WEEE, BSMI CNS 13438, FCC Part 15 A, ACA, REACH, VCCI V-3
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
43.61 cm
55.5 cm
13.21 cm
21.3 kg
10 °C
35 °C
20 - 80%
Scroll to top
