BT.com
Wishlist
Drobo 10TB (5 x 2TB WD Red) 5N 5 Bay Desktop NAS Storage Device
Drobo 10TB (5 x 2TB WD Red) 5N 5...
£830.76
28 in stock
£830.76
Add to wishlist
Delivery
Standard 1-3 working days
The Drobo 5N was designed with one purpose in mind: to deliver the best ever experience sharing storage and accessing data. From the moment you plug it in and it is instantly accessible on your network, you'll know there's nothing like it. The Drobo 5N is perfect for any connected home, home office, or small office environment needing a simple, safe device for sharing and backing up data over the network.
Not only is Drobo 5N fast, but it's easy-to-use, expandable, flexible, and protected - exactly what's expected from a Drobo. You can safely store and edit photos, videos, and audio files as well as store and back up all the computers on your network.
Drobo 5N - NAS server - 10 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
10 TB
5 (installed) / 5 (max)
15.03 cm
26.23 cm
18.54 cm
3.9 kg
Built-in Devices
Led panel
Storage Controller
SATA - internal
Interface Type
SATA 6Gb/s
Data Transfer Rate
600 MBps
Hard Drive
HDD - hot-swap - 3.5"
5 x 2 TB
Network adapter - integrated
10Mb LAN, 100Mb LAN, GigE
Network Services Compatibility
Microsoft CIFS, Server Message Block (SMB), Apple File Protocol (AFP)
Jumbo Frames support, Apple Time Machine compatible
Expansion Bays
5 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
1 x Ethernet 1000Base-T - RJ-45
1 x network cable - 1.8 m
Security lock slot (cable lock sold separately), BeyondRAID technology, built-in cooling fan
X internal power supply
Power Provided
150 Watt
Software Included
Drivers & Utilities, Drobo Dashboard, Apple Time Machine
Microsoft Windows 7 (32/64 bits) SP1, Apple MacOS X 10.7 Lion, Windows 8 (32/64 bits), Apple MacOS X 10.8.x
Other bundles
Drobo 10TB (5 x 2TB WD Red) 5N 5 Bay Desktop NAS...
£830.76
C2G Cat6 Cable with NAS Device
Save £5.00
£835.75
£830.76
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.25
£834.01
Scroll to top
