BT.com
Wishlist
DrayTek Vigor 2920Vn
Delivery
Standard Due date unavailable
The Vigor2920Vn is firewall broadband routers for connecting to xDSL/cable/VDSL2/Ethernet FTTx. The Gigabit WAN and 4-port Gigabit LAN switch facilitates unified communication applications in business CO/remote site to handle large data from subscribed higher speed broadband. The state-of-art router feature, VPN, security, dual WAN provides integrated benefits for professional users and small offices.
Its well-structured Web User Interface (WUI) offers user-friendly configuration and allows specific setting to satisfy users' various needs. The WUI also provides IP layer QoS (Quality of Service), NAT session/bandwidth management to help users control and allocate the bandwidth on networks.
In short, the WUI of Vigor2920 series give you a nice and smooth way to operate all enrich features you need.
Draytek Vigor 2920Vn - wireless router - 802.11b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
VPN tunnels: 32
Network / Transport Protocol
PPTP, L2TP, NTP, IPSec, PPPoE, DHCP, DNS
Routing Protocol
RIP-2, static IP routing
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
VoIP Functionality
VoIP phone adapter
VoIP Protocols
SIP
Telephony Interfaces
2 phone (FXS)
Firewall protection, DMZ port, DHCP support, NAT support, VPN support, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, packet filtering, dynamic DNS server, E-mail alert, print server, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, Outbound Load Balancing, firmware upgradable, DDos attack prevention, MIMO technology, LAN-to-LAN bridging, P2P client, Wi-Fi Multimedia (WMM) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), RADIUS support, Wi-Fi Protected Setup (WPS), WAN failover, DHCP server, Samba support, FTP server, Multiple SSID support, hidden SSID, DNS proxy, Bandwidth-On-Demand (BOD), UPnP Internet Gateway Device, Cable Diagnostics Function, bandwidth control
IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n
16.5 cm x 24.1 cm x 4.4 cm
2 years warranty
Enclosure Type
Desktop
Wireless, wired
VPN tunnels: 32
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, MPPE, AES, 128-bit WEP, 64-bit WEP, SHA-1, WPA, WPA2
Authentication Method
RADIUS, X.509 certificates, Radio Service Set ID (SSID)
IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, FCC
IP Telephony
VoIP Functionality
VoIP phone adapter
VoIP Protocols
SIP
Voice Codecs
G.723.1, G.729ab, G.711a, G.726, iLBC, T.38
2 phone (FXS)
IP Telephony Features
Comfort noise generation (CNG), voice activity detection (VAD), echo cancellation (G.168), call forwarding, Caller ID, adaptative jitter buffer, call waiting, call hold, call transfer, gain control, DTMF generation/detection
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , Phone line: 2 x FXS - RJ-11 , USB 2.0: 1 x 4 pin USB Type A , Phone line: 1 x RJ-11
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
10 Watt
Software Included
Drivers & Utilities
16.5 cm
24.1 cm
4.4 cm
45 °C
10 - 90% (non-condensing)
Accessories
Get the most from your Router
£43.52
Scroll to top
