BT.com
Wishlist
DrayTek Vigor 2860Vac - VDSL Router 802.11ac & VoIP
Delivery
Standard Due date unavailable
The Vigor 2860AC features 802.11ac wireless LAN, providing increased speed and performance.
Draytek Vigor 2860VAC - wireless router - DSL modem - 802.11ac - desktop
Wireless router - DSL modem - 6-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, VDSL, ADSL2, ADSL2+, READSL, VDSL2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Performance
Firewall throughput: 200 Mbps , VPN throughput (IPSec): 50 Mbps
VPN tunnels: 32 , SSL VPN users: 5
Network / Transport Protocol
PPTP, L2TP, NTP, IPSec, PPPoE, PPPoA, AAL5, FTP, DHCP, DNS, DDNS
Routing Protocol
RIP-2, IGMPv2, static IP routing, IGMPv3
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, TFTP, SSH, CLI, TR-069
VoIP Functionality
VoIP phone adapter
VoIP Protocols
SIP, SIP v2, RTCP, RTP, SRTP, ZRTP
Telephony Interfaces
2 phone (FXS)
Firewall protection, DMZ port, DHCP support, NAT support, VPN support, load balancing, VLAN support, IGMP snooping, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, dynamic DNS server, DiffServ support, E-mail alert, print server, MAC address filtering, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, Access Point operational mode, PSTN Lifeline, firmware upgradable, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), RADIUS support, Wi-Fi Protected Setup (WPS), WAN failover, DHCP server, Samba support, FTP server, Multiple SSID support, DNS proxy, reset button, bandwidth control, IPv4 support, DHCP relay, Stateful Packet Inspection Firewall (SPIF), 3G/4G USB Dongle Support, anti-spoofing protection, DHCP client, Management Information Base (MIB), static routing, tagged VLAN, Diagnostic Function, IM/P2P filter, DNS caching, IGMP proxy, Content Security Management (CSM), automatic gain control (AGC), Type of Service (ToS), DiffServ Code Point (DSCP) support
IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x, IEEE 802.3ah, IEEE 802.11e, UPnP, IEEE 802.11ac
24.096 cm x 16.507 cm x 4.396 cm
United Kingdom
2 years warranty
Wireless router - 6-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, MPPE, AES, 128-bit WEP, 64-bit WEP, IKE, SSL, SHA-1, WPA, WPA2
Authentication Method
RADIUS, X.509 certificates, Radio Service Set ID (SSID)
IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x, IEEE 802.3ah, IEEE 802.11e, UPnP, IEEE 802.11ac, X.509
Built-in Devices
Led panel
Status Indicators
Power, WLAN, WAN, link/activity, USB, ADSL, VPN
Line Properties
Framing Format
ANSI T1.413i2
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.997.1, ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.993.1, ITU G.993.2
IP Telephony
VoIP Functionality
VoIP phone adapter
VoIP Protocols
Voice Codecs
G.711, G.722, G.723, G.729a, G.711a, G.726, iLBC, G.729b
2 phone (FXS)
IP Telephony Features
Comfort noise generation (CNG), voice activity detection (VAD), echo cancellation (G.168), call forwarding, Caller ID, call waiting, automatic fax/modem detection and pass-through, call hold, call transfer, message waiting, DTMF generation/detection, dynamic jitter buffer
LAN: 6 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Phone line: 2 x FXS - RJ-11
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
United Kingdom
24.096 cm
16.507 cm
4.396 cm
45 °C
10 - 90% (non-condensing)
Scroll to top
