BT.com
Wishlist
DrayTek Vigor 2860Ln LTE Wireless Router
Delivery
Standard Due date unavailable
Vigor 2860 series security firewall router has built-in VDSL2/ADSL2+ modem, plus a second Ethernet WAN port for cable or satellite broadband, and 2 USB ports for 3G/4G mobile broadband access. With the multi-WAN accesses, Vigor 2860 router supports bandwidth management functions such as fail-over and load balancing, making them ideal solutions for reliable and flexible broadband connectivity for small to large enterprises.
Draytek Vigor 2860LN - wireless router - DSL/WWAN - 802.11b/g/n - desktop
Wireless router - DSL modem / wireless cellular modem - 6-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+, READSL, VDSL2
Cellular Protocol
GPRS, EDGE, WCDMA, LTE
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
VPN tunnels: 32 , SSL VPN tunnels: 16 , UPnP sessions: 30
Network / Transport Protocol
PPTP, L2TP, NTP, PPPoE, PPPoA, FTP, DHCP
Routing Protocol
RIP-2, IGMPv2, static IP routing, IGMPv3
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, TFTP, SSH, CLI, TR-069
Firewall protection, DMZ port, VPN support, trunking, load balancing, VLAN support, IGMP snooping, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, dynamic DNS server, E-mail alert, MAC address filtering, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, firmware upgradable, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), Wi-Fi Protected Setup (WPS), WAN failover, DHCP server, Multiple SSID support, hidden SSID, DNS proxy, reset button, bandwidth control, Wireless Client Mode, DHCP relay, anti-spoofing protection, DHCP client, tagged VLAN, Diagnostic Function, DNS caching, IGMP proxy, Type of Service (ToS), DiffServ Code Point (DSCP) support
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.3ah, IEEE 802.11e, IEEE 802.11n, UPnP
24.1 cm x 16.5 cm x 4.4 cm
United Kingdom
Wireless router - 6-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, MPPE, AES, 128-bit WEP, 64-bit WEP, IKE, SHA-1, WPA, WPA2
Authentication Method
Secure Shell (SSH), RADIUS, X.509 certificates, Radio Service Set ID (SSID)
Built-in Devices
Led panel
Status Indicators
Power, WLAN, WAN, link/activity, USB, DSL
Communications
Cellular Protocol
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.3 (G.DMT.bis), ITU G.992.1 (G.DMT) Annex A, ITU G.992.3 Annex A, ITU G.993.2, ITU G.992.5 Annex A
Max Transfer Rate
150 Mbps
LAN: 6 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter
24 Watt
Rack Mounting Kit
Optional
United Kingdom
24.1 cm
16.5 cm
4.4 cm
45 °C
10 - 90% (non-condensing)
Scroll to top
