BT.com
Wishlist
Draytek Vigor 2760 Router
Delivery
Standard Due date unavailable
Now with "DrayOS Firmware!"
Vigor 2760 provides connectivity to your PCs or other Internet-connected devices (laptops, tablets, games consoles, smartphones) via its built-in Gigabit ports, or using Wireless LAN (on 'n' models). The firewall helps protect your network from external threats, as well as the Vigor2760's built-in content filtering which gives you control over what and when your local users can access or download. For Wireless LAN usage, the Vigor2760n version supports multiple security methods, including strong encryption but also hardware-specific authorization and selectable client isolation (from each other).
The Vigor 2760 supports all variants of mass-market DSL technology available, so if you have ADSL today it will work with that, but when VDSL (FTTC) comes to your area later, you're ready, already. VDSL is available from BT under their 'Infinity ' service, currently providing downstream speeds of up to 160Mb/s (depending on local service). Other ISPs are also starting to introduce VDSL across the country so coverage continues to increase. You can also use 3G/4G networks.
Draytek Vigor 2760 - router - DSL modem - desktop
Router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
VDSL, ADSL2, ADSL2+, VDSL2
VPN tunnels: 2 , UPnP sessions: 30 , NAT sessions: 20000
Network / Transport Protocol
PPTP, L2TP, NTP, IPSec, PPPoE, PPPoA, DHCP, DNS, DDNS
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP, static IP routing, IGMPv3
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH, CLI, TR-069
Firewall protection, DMZ port, DHCP support, NAT support, VLAN support, IGMP snooping, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, E-mail alert, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, firmware upgradable, DDos attack prevention, Quality of Service (QoS), Dead Peer Detection (DPD), RADIUS support, DHCP server, DNS proxy, reset button, IPv4 support, DLNA Media Server, 3G/4G USB Dongle Support, IP-MAC binding, on/off switches, DHCP client, static routing, Diagnostic Function, IM/P2P filter, DNS caching, IGMP proxy
IEEE 802.1Q, UPnP
18.2 cm x 12.5 cm x 4 cm
2 years warranty
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Wired
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, MPPE, AES, IKE, SHA-1
Authentication Method
RADIUS, X.509 certificates
IEEE 802.1Q, UPnP, FCC Part 15 B
Built-in Devices
Led panel
Status Indicators
Power, LAN, link/activity, USB
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.997.1, ITU G.992.5, ITU G.992.5 Annex M, ITU G.993.1, ITU G.993.2
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 2 x 4 pin USB Type A
External power adapter
1 x network cable
Software Included
Drivers & Utilities
18.2 cm
12.5 cm
4 cm
10 - 90% (non-condensing)
Scroll to top
