Click to visit BT.com
BT.com
Wishlist
DrayTek Vigor 120 ADSL2+ Ethernet Modem
5.0*
Quicklinx: 5JWNWS00
Mfr#: V120-K
Type: DSL modem
Enclosure: External
Interface: Fast Ethernet
Compatibility: PC
Standard delivery Delivered within 3-5 working days
More than 50 in stock
£50.80
The DrayTek Vigor 120 is an ADSL modem with an Ethernet connection; it is not a router but a true ADSL Ethernet modem. By providing a PPPoE to PPPoA bridge, the connected device (firewall, router or PC) can log into the Internet (your ISP) directly and have full control over the ADSL connection - that makes the Vigor 120 a unique product. You can connect any device to the Vigor 120 which has a PPPoE client facility, which includes PCs, most Ethernet-WAN routers and the Apple Airport but the actual connection to your ISP is still PPPoA (unlike other modems which only provide PPPoE native bridging), which is the unique feature of this product and makes it compatible with all UK ISPs, where PPPoA is used as standard.
Other ADSL Ethernet 'modems' use workarounds to get a public IP address 'through' to your secondary device/client, requiring non-standard operation and complicated dual-stage setup (modem logs in, router routes) but the Vigor 120 provides the secondary device with a real routed IP connection and the ability to fully manage the connection, making setup easy. In most cases, the Vigor 120 needs no setup or configuration - just plug it in and set up your PC or router. All login/ISP details are entered on the connected client device, not the Vigor 120.
This method also differs from using a regular ADSL router which logs in itself and then uses NAT or multiple public IP addresses to create an onward client connection for your secondary device; that is not IP address thrifty, or introduces secondary NAT compromises. With the Vigor 120 bridge/modem, you get a true single public IP address (or multiple, if you have them) straight through to your firewall/router, which also has complete control of the ISP connection.
DrayTek Vigor 120 - DSL modem
DSL modem - Ethernet 100
External
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.5
10.6 cm x 9 cm x 2.6 cm
DSL modem
External
Modem
Bus
Ethernet 100
Wired
ADSL, ADSL2, ADSL2+
Network / Transport Protocol
PPPoE, PPPoA
1 x modem - ADSL - RJ-11 , 1 x 100Base-TX - RJ-45
Power adapter
10.6 cm
9 cm
2.6 cm
20 - 90%
DrayTek Vigor 120 ADSL2+ Ethernet Modem Bundle deal on DrayTek Vigor 120 ADSL2+ Ethernet Modem
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£60.79
Customer reviews
Write a review for the DrayTek Vigor 120 ADSL2+ Ethernet Modem here!
Draytek Vigor 120 ADSL2 Modem
Reviewed by Anonymous Review Posted 17/06/2010
I highly recommend this product - it does its job, there was no setup needed (just plug it in) and it's been reliable.
I used to do what most people do have an all-in-one wireless adapter/router/dhcp-server/modem. Well that's a pain to diagnose when something goes wrong.
I have a BT broadband service(they run a PPPoA signal in the UK).Just plugging this modem into the telephone line and all it does is act as a modem - simply converting the PPPoA signal to a PPPoE signal. This then allows me to connect a router to the modem with an ethernet cable and set the router to be a PPPoE client (router is now a acting as a bridge). All my router does is maintain the BT broadband service account details, and provide the usual NAT/DHCP/IP filtering, etc.
Now if anything fails it just a single point of failure.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Works perfectly
Reviewed by Michael McNally. Review Posted 29/11/2010
Flawlessly worked out of the box. Replaced a Linksys AM200 in Router Mode and now have the Apple Time Capsule as a PPPoE client.
Back to Mac now working correctly without having to mess about like with the AM200.
Recommend to anyone with Apple Time Capsule / Airport Extreme in the UK
Also seemed slightly quicker as well.
  • Overall 5*
  • Ease of use 5*
Perfect for Airport Extreme
Reviewed by Paul. Review Posted 21/10/2011
This could be an Apple device....just plug it in and it works.
  • Overall 5*
  • Ease of use 5*
Good product
Reviewed by Steve. Review Posted 18/09/2011
Works perfectly - apart from the power adaptor, which was dead on arrival. But I had another, so I wasn't too inconvenienced.
Works well with Apple TimeMachine wireless router that controls the ISP connection via a PPoE.
Rather expensive for what it is.
  • Overall 5*
  • Ease of use 5*
  • Value for money 3*
Superb!
Reviewed by Peter Danckwerts. Review Posted 12/11/2010
I previously had a Huawei SmartAX MT882 supplied by TalkTalk when I signed up with them. It looked ugly but did the job, until yesterday when it just stopped working. Unlike the Huawei, the Draytek Vigor was so easy to set up that I didn't even have to touch its settings, just change a setting on my wireless router (Airport Extreme). From receiving the package at 9 a.m., it took about 5 minutes to set up. It may just be coincidence, but my download speed, which has been about 11 MBits per second is now up to 14. Very small and neat, too. Would highly recommend. Hoorah for BT!
  • Overall 5*
  • Ease of use 5*
First Rate bit of kit
Reviewed by Lim. Review Posted 30/11/2010
This has turned out to be the perfect device to use with my Apple Airport Extreme (also highly recommended for all sorts of reasons.)
The Vigor 120 worked well and reliably from day one and speeds have apparently increased by around 20%. I was initially uncertain as to which firmware update options to adopt but was advised promptly by Draytek in the UK. Whilst this modem has no settings to adjust or alter (it does work straight out of the box), it is very useful indeed that Draytek in the UK has detailed instructions and advice on using this modem with particular ISPs and routers like the Airport Extreme.
Not cheap, but because of reliability and performance a 5 for VFM. I am extremely satisfied with the Vigor 120 and with Draytek (UK).
  • Overall 5*
  • Ease of use 5*
Works straight out of the box
Reviewed by Grant. Review Posted 14/12/2010
Whilst not the cheapest, anyone who has set up a new router and broadband connection knows that the real cost is all the time messing about to get it going.
Plugged in the Draytek (already pre-configured) straight out the box into my ADSL connection and then my Apple Time Capsule. Then a few clicks on the Apple Airport Utility to put in my ADSL user details / password and it works.
I'd set aside a good chunk of the weekend just in case but simply not needed! Also there is excellent advice/tips on the Draytek web site.
  • Overall 5*
  • Ease of use 5*
Does what it says on the tin, very fast
Reviewed by Max Bolingbroke. Review Posted 05/05/2012
I replaced the TG585v7 router/modem I got from my ISP with a E3000 + this modem to get dual-band Wireless N for my home. I wasn't expecting any speed difference from this change, but I found that with the Vigor my internet connection speed increased from 1.3MB/s to 1.8MB/s and my ping to google.com fell from 33ms to 30ms. This modem seems a bit pricy for what it does, but it does do it very well. Recommended!
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
Excellent!
Reviewed by Martin Gordon. Review Posted 16/10/2012
The main advantage to me of this modem is that the setup is done in the firewall: if the modem should fail I can just plug another one in with no re-configuration to be done.
  • Overall 5*
  • Ease of use 5*
Vigor 120 + Apple Airpot Extreme = 5*
Reviewed by Stefan. Review Posted 27/04/2013
Cannot fault. Works out of the box. No messing. Plug and play at it's best. Faultless. Apple Airport Extreme picked it up immediately. Entered connection settings and away I went. Painless and frustration free.
  • Overall 5*
  • Ease of use 5*
read all 16 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Accessories Packaging Functional Software Manuals
Ref: 5JWN 033758
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £43.77
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: DSL modem
Enclosure: External
Compatibility: PC
Brand: DrayTek
Stock Status: Used Stock
Price Range Inc VAT: 50 - 100
