Click to visit BT.com
BT.com
Wishlist
Dicota MULTI ROLLER 14-15.6"
Quicklinx: 8469WS00
Mfr#: D30414
Essential accessories
Spacious trolley with tablet pocket
Multi Roller lets you transport your notebook securely and comfortably and also has space for your accessories and other personal belongings. The notebook is safely protected in a designated notebook compartment with metal wire frame. This compartment is cushioned with High Density Foam and has a strap that keeps the notebook in place. For your tablet there is a padded pocket designed to fit tablet PCs up to 10".
The second main compartment is spacious enough for clothes or folders and there is also a slip pocket for documents. Accessories such as mobile phone, pens, passport and business cards are always at reach in the compartments in the front pocket. The bag has high quality wheels that roll smoothly and they can also be replaced if needed. Multi Roller has a comfortable handle and a removable padded shoulder strap for when you want to carry the bag. On the back of the case there is also a trolley fastening strap should you want to put Multi Roller on top of another bag.
  • Cushioned (High Density foam) and lockable notebook compartment with metal wire frame
  • Padded compartment for tablet PC (up to 10")
  • Large main compartment for clothes etc
  • Front compartment with pockets for accessories such as pens, mobile phone, passport etc
  • Document compartment on the back
  • Comfortable carrying handle
  • Removable, padded shoulder strap
  • High quality exchangeable wheels
DICOTA Multi Roller notebook carrying case
Notebook carrying case
45 cm x 25 cm x 37 cm
3.45 kg
Notebook Compatibility
15.6"
Padded
Telescopic Handle / Wheels
45 cm
25 cm
37 cm
3.45 kg
15.6"
Notebook Compatibility Dimensions
38 cm x 26.5 cm x 4 cm
Padded
