BT.com
Wishlist
Devolo Home Control Starter Pack
£159.99
Hurry, only 1 left in stock!
£159.99
Add to wishlist
Delivery
Standard 1-3 working days
Now the smart home comes to you! The devolo Home Control Starter Pack lets you get started right away. With all the important components (three central components) in one package, the Starter Pack offers the optimal basis to turn your home into a smart home in no time
Includes:
  • devolo Home Control Central Unit
  • devolo Home Control Door/Window Contact
  • devolo Home Control Smart Metering Plug
The devolo Home Control Central Unit
forms the centrepiece of your smart home. It discreetly ensures that all Home Control components of your smart home work with each other without a hitch. Installing the Starter Pack takes just a few minutes: Unpack and install with adhesive foil or screws - and enjoy the benefits of your smart home automation system. Because of the intuitive operation, getting started with the devolo Home Control Starter Pack is no problem, even for inexperienced users. You can also extend your smart home afterwards with additional devolo Home Control components if desired.
The devolo Home Control Door/Window Contact offers you maximum security against invasions and unauthorised access to sensitive areas. It reliably detects open doors, windows or drawers and sounds the alarm if something isn't right, or automatically switches the lights on and off and additionally controls your radiators. You can also be informed via text* and e-mail, if desired. The contacts can quickly and easily be fastened to the desired position via adhesive foil or screws. Both are, of course, already contained in the scope of delivery.
Bring a bit of extra convenience into the home with the Smart Metering Plug. While you are still sleeping, your intelligent electrical socket is already working: It brews fresh coffee in combination with your coffee machine, turns devices off that you have forgotten or warns you if the refrigerator is still open. You also have an overview of the power consumption of the connected devices and can quickly identify "energy hogs" using the measurement function of the electrical socket.
Like all devolo Home Control products, the components delivered in the devolo Home Control Starter Pack are easily operated via the free my devolo iOS and Android app via your smartphone, tablet or using the my devolo online portal on the computer. Your smart home is always just one push of a button away, no matter where you are.
With devolo Home Control, you are buying future-proof technology via the standardised Z-Wave® wireless technology with a three year manufacturer's warranty. There are no monthly follow-up costs after purchase. Our team of experts additionally offers you comprehensive support via phone, e-mail or live chat before, during and after the installation of Home Control.
Product contents:
  • 1 x dLAN Home Control Central Unit (W/H/D: 72 x 132 x 42 mm)
  • 1 x dLAN Home Control Smart Metering Plug (W/H/D: 57.7 x 94.5 x 76.6 mm)
  • 1 x dLAN Home Control Door/Window Contact (Sensor: W/H/D: 28 x 96 x 23 mm, Magnet: W/H/D: 10 x 50 x 12 mm) including batteries and mounting material
  • 1 x installation manual 1 x Ethernet cable 2 m, white
devolo Home Control Starter Paket - home automation kit
Home automation kit
Package Content
Motion sensor, central controller, smart plug
Wireless - Z-Wave
Remote Management Interface
Ethernet 10/100, USB
Supported Host Device OS
iOS, Android
3 years warranty
Home automation kit
Package Content
Wireless - Z-Wave
Max Range Indoors
20 m
Max Range Open Space
100 m
Apple MacOS X 10.6, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 64-bit Edition, Apple MacOS X 10.8, Windows 8 Pro 64-bit Edition, Windows 8 32-bit Edition, Windows 8 Pro 32-bit Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Windows 8.1 Pro 64-bit Edition, Apple MacOS X 10.9, Windows 8.1 Pro 32-bit Edition, Ubuntu Linux 12.04
Android 4.0 (Ice Cream Sandwich) or later, iOS 5.0 or later
Control Unit
USB , LAN
Motion Sensor
Detection Range
10 m
CR123A lithium battery
Encryption Algorithm
128-bit AES
Warranty
3 years warranty
Dimensions & Weight Details
Motion sensor: 2.8 cm x 2.3 cm x 9.6 cm , Smart plug: 5.77 cm x 7.66 cm x 9.45 cm , Central controller: 13.2 cm x 4.2 cm x 7.2 cm
Resources
The following resources are available for the Devolo Home Control Starter Pack
Scroll to top
