BT.com
Wishlist
Devolo Home Control Smart Metering Plug
Devolo Home Control Smart Metering...
£39.99
3 in stock
£39.99
Add to wishlist
Delivery
Standard 3-5 working days
Your outlet becomes smart
  • The activation and disabling of connected devices such as lamps, the coffee machine, radio, can be time-controlled.
  • Ready to use in no time: simply plug it in between the power socket and desired device.
  • Finally, an end to unnecessary and high standby consumption of your devices.
  • Measures the power consumption unobtrusively in the background and records it.
  • Intuitive operation by browser, and a free app for smartphones and tablets.
  • Individually expandable at any time with other devolo Home Control components.
  • Future-proofed thanks to standardised Z-Wave┬« wireless technology.
  • 3-year manufacturer's warranty.
Never get cold feet again at your favourite seat. The devolo Room Thermostat provides your own individualised temperature where you actually spend time; after all, you usually don't sit directly next to the radiator. It equalises the temperature gradient between the radiator and your favourite seat. It functions simultaneously as a convenient "remote control" for all connected radiators in one room or on one storey. That's how energy saving is made even simpler with devolo Home Control!
devolo Home Control Smart Metering Plug - smart plug
Smart plug
Wireless - Z-Wave
Frequency Band
868.42 MHz
United Kingdom
3 years warranty
5.77 cm x 7.66 cm x 9.45 cm
Smart plug
Wireless - Z-Wave
Max Range Indoors
20 m
Max Range Open Space
100 m
Frequency Band
868.42 MHz
Apple MacOS X 10.6, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 64-bit Edition, Apple MacOS X 10.8, Windows 8 Pro 64-bit Edition, Windows 8 32-bit Edition, Windows 8 Pro 32-bit Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Windows 8.1 Pro 64-bit Edition, Apple MacOS X 10.9, Windows 8.1 Pro 32-bit Edition, Ubuntu Linux 12.04
Indoor usage
United Kingdom
Power Provided
3000 Watt
Warranty
3 years warranty
0.48 Watt
5.77 cm
7.66 cm
9.45 cm
10 - 85% (non-condensing)
Scroll to top
