BT.com
Wishlist
Devolo Home Control Room Thermostat
Devolo Home Control Room...
£79.99
13 in stock
£79.99
Add to wishlist
Delivery
Standard 3-5 working days
Your ideal temperature is always at your fingertips!
  • Determine the exact room temperature at any time.
  • Easy and central unit control of the room temperature (when combined with the devolo Home Control radiator thermostats).
  • Comfortable temperatures exactly where you spend time, not just at the radiator.
  • Manual temperature control directly on the thermostat at the touch of a button.
  • Illuminated display to show temperature.
  • Ready to use in no time: can be installed easily, without special tools or expertise.
  • Individually expandable at any time with other devolo Home Control components.
  • Future-proofed thanks to standardised Z-Wave┬« wireless technology.
  • 3-year manufacturer's warranty.
Never get cold feet again at your favourite seat. The devolo Room Thermostat provides your own individualised temperature where you actually spend time; after all, you usually don't sit directly next to the radiator. It equalises the temperature gradient between the radiator and your favourite seat. It functions simultaneously as a convenient "remote control" for all connected radiators in one room or on one storey. That's how energy saving is made even simpler with devolo Home Control!
devolo Home Control Room thermostat - thermostat
Thermostat
Wireless - Z-Wave
Frequency Band
868.42 MHz
Thermostat
LCD
United Kingdom
3 years warranty
7.5 cm x 2.4 cm x 7.5 cm
Thermostat
Wireless - Z-Wave
Max Range Indoors
20 m
Max Range Open Space
100 m
Frequency Band
868.42 MHz
Apple MacOS X 10.6, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 64-bit Edition, Apple MacOS X 10.8, Windows 8 Pro 64-bit Edition, Windows 8 32-bit Edition, Windows 8 Pro 32-bit Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Windows 8.1 Pro 64-bit Edition, Apple MacOS X 10.9, Windows 8.1 Pro 32-bit Edition, Ubuntu Linux 12.04
Indoor usage
Thermostat
Modes
Manual
Display
LCD
Backlit display
2 AA batteries
United Kingdom
Battery Required
2 x AA type
Warranty
3 years warranty
IP21
7.5 cm
2.4 cm
7.5 cm
10 - 95% (non-condensing)
Scroll to top
