BT.com
Wishlist
Devolo Home Control Radiator Thermostat
Devolo Home Control Radiator...
£59.98
16 in stock
£59.98
Add to wishlist
Delivery
Standard 3-5 working days
Your ideal temperature any time of day.
  • Controls the room temperature by a time control depending on your individual daily routine. It provides flexibility for programming each day of the week.
  • Holiday mode for maximum energy saving.
  • Fits most current radiators. Simply replace conventional radiator thermostats.
  • Ready to use in no time: can be installed easily, without special tools or expertise.
  • Manual temperature control at the thermostat, and intuitive operation via an app for smartphone, tablet and computer.
  • Illuminated display to show temperature.
  • Individually expandable at any time with other devolo Home Control components.
  • Future-proofed thanks to standardised Z-Wave┬« wireless technology.
  • 3-year manufacturer's warranty.
The devolo Radiator Thermostat ensures your personal and individual temperature at the right time and in the right room. Thanks to the time control that can be individually programmed for each day of the week, your bathroom, kitchen or living room will always be the correct temperature when you are there. The radiator can automatically turn down when you're not home. That's how smart energy saving is today!
The devolo Radiator Thermostat can be installed in no time, without any special tools or expertise. Your conventional Radiator Control can be replaced in under a minute. You can, of course, set the new thermostats also manually, if necessary. Using an app, you have access to your room temperature at any time, even at a distance and can warm up your house on your way home, for example.
devolo Home Control Radiator Thermostat - radiator thermostat
Radiator thermostat
Wireless - Z-Wave
Frequency Band
868.42 MHz
Thermostat
LCD
United Kingdom
3 years warranty
5.1 cm x 9.1 cm x 5.1 cm
Radiator thermostat
Wireless - Z-Wave
Max Range Indoors
20 m
Frequency Band
868.42 MHz
Apple MacOS X 10.6, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 64-bit Edition, Apple MacOS X 10.8, Windows 8 Pro 64-bit Edition, Windows 8 32-bit Edition, Windows 8 Pro 32-bit Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Windows 8.1 Pro 64-bit Edition, Apple MacOS X 10.9, Windows 8.1 Pro 32-bit Edition, Ubuntu Linux 12.04
Thermostat
Temperature Range
4 - 28 °C
Display
LCD
Backlit display
2 AA batteries
United Kingdom
Battery Required
2 x AA type
Warranty
3 years warranty
IP20
5.1 cm
9.1 cm
5.1 cm
10 - 90% (non-condensing)
Scroll to top
