BT.com
Wishlist
Devolo Home Control Motion Sensor
£49.99
£49.99
Add to wishlist
Delivery
Standard Due date unavailable
Discreet, alert, smart.
  • Reliably identifies movements of people, animals and objects and sends text*, e-mail or app notifications.
  • Versatile installation via adhesive film or screws (included in the box contents).
  • Continuous brightness measurement, e.g. as feedback to the light controls.
  • Intuitive operation by browser, and a free app for smartphones and tablets.
  • Unobtrusive design for inconspicuous placement.
  • Individually expandable at any time with other devolo Home Control components.
  • Future-proofed thanks to standardised Z-Wave┬« wireless technology.
  • 3-year manufacturer's warranty.
*devolo provides you with 15 free SMS messages. For additional notifications, you can purchase a devolo Home Control SMS pack.
The devolo Motion Sensor can be discreetly placed in your smart home and keeps a watchful eye on the surrounding area. It reliably detects every movement in an angle of up to 80 degrees and intelligently distinguishes between people, animals and objects (e.g. a door that moves because of a draft). The devolo Motion Sensor notifies you of the recorded movements via text or e-mail so you can stay informed even when not at home. Your smart home is always safely protected! Thanks to the infrared sensor, the Motion Sensor works just as precisely at night as it does during the day. Its individually configurable light sensor additionally makes it a versatile signal generator for a series of other Home Control components, such as the light controls.
devolo Home Control Motion Sensor - multipurpose sensor
Multipurpose sensor
Sensor Type
Temperature, motion
Wireless - Z-Wave
Frequency Band
868.42 MHz
2.8 cm x 2.3 cm x 9.6 cm
Multipurpose sensor
Sensor Type
Temperature, motion
Wireless - Z-Wave
Max Range Indoors
20 m
Max Range Open Space
100 m
Frequency Band
868.42 MHz
Ubuntu 12.04, Apple MacOS X 10.6 - 10.9, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits)
Indoor usage
Motion Sensor
Detection Mode
Passive infrared (PIR)
Detection Range
10 m
CR123A lithium battery
Battery Required
CR123A
WEEE
2.8 cm
2.3 cm
9.6 cm
-10 °C
10 - 85% (non-condensing)
Scroll to top
