BT.com
Wishlist
Devolo Home Control Key-Fob Switch
£34.99
15 in stock
£34.99
Add to wishlist
Delivery
Standard 3-5 working days
The smart home controller for your trouser pocket!
  • Four programmable buttons for operating selected Home Control components, e.g. switching all lighting on/off or switching the heat on/off.
  • Easily control individual Home Control components, groups or scenarios at the touch of a button.
  • As compact and lightweight as a regular car key.
  • Control your Smart Home from a distance of up to 100 metres (328 ft.).
  • Protection against unintentionally pressing a button.
  • Easily programmable via an app or on the computer.
  • Child-safety features can be activated.
  • Individually expandable at any time with other devolo Home Control components.
  • Future-proof thanks to standardised Z-Wave® wireless technology.
  • 3-year manufacturer's warranty.
With the devolo Key-Fob Switch your smart home will be more versatile than ever before. Switch your device groups on or off at the touch of a button or transfer your entire house to night mode – the devolo Key-Fob Switch makes it possible! It’s as compact and lightweight as a regular car key and is completely individual and freely programmable. Conveniently available on your key ring, a button can be activated when you leave the house and your smart home automatically goes to power save and alarm mode. The highlight is that this even works up to 100 metres (328 ft.) away!
devolo Home Control Remote control - remote control
Remote control
Wireless - Z-Wave
Frequency Band
868.42 MHz
United Kingdom
3 years warranty
3 cm x 1.4 cm x 5.5 cm
Remote control
Wireless - Z-Wave
Max Range Indoors
20 m
Max Range Open Space
100 m
Frequency Band
868.42 MHz
Apple MacOS X 10.6, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 64-bit Edition, Apple MacOS X 10.8, Windows 8 Pro 64-bit Edition, Windows 8 32-bit Edition, Windows 8 Pro 32-bit Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Windows 8.1 Pro 64-bit Edition, Apple MacOS X 10.9, Windows 8.1 Pro 32-bit Edition, Ubuntu Linux 12.04
CR2032 battery
United Kingdom
Battery Required
CR2032
Warranty
3 years warranty
IP20
3 cm
1.4 cm
5.5 cm
10 - 85% (non-condensing)
Scroll to top
