BT.com
Wishlist
Devolo dLAN 650 Triple Plus - Kit - Gigabit Ethernet
Devolo dLAN 650 Triple Plus - Kit -...
£99.40
£99.40
Add to wishlist
Delivery
Standard Due date unavailable
Faster and more versatile than ever before, the Devolo 9238 dLAN 650 Triple+ AV2 600 HomePlug starter kit helps expand your home network in any room you choose. Using the existing electrical wiring in your home, you can now connect up to three devices that are located away from your router at speeds up to 600 Mbps. This Devolo 9242 dLAN 650 Triple+ AV2 600 HomePlug starter kit includes everything you need to get started or upgrade an existing Devolo HomePlug setup.
Complete HomePlug starter kit, includes everything you need to get started
The fastest connection at up to 600 Mbps using the AV2 HomePlug standard
Even higher performance and longer range with the latest technology
Connect three (3) devices using the integrated Gigabit LAN ports
The integrated socket ensures that no electrical outlet is lost
The easy way to connect using your home's power lines
Includes dLAN Cockpit software for home network configuration
Automatic encryption! Active protection against unauthorised access
Optimal Internet connection for computers, televisions and game consoles
Compatible with all adapters of the 200/500/650 Mbps product series
Pass-Through Electrical Socket
Featuring a pass-through socket, both of the Devolo dLAN 650 AV2 600 HomePlug adapters in this starter kit can alleviate any lost of a socket by simply allowing another device to be plug directly into the HomePlug.
3 x Gigabit LAN Ports
With a -port Gigabit LAN connection, you can connect an Internet-compatible device (e.g. game console, television or media receiver) to the Internet at any time via an Ethernet network cable directly to the HomePlug in this kit.
Standard Warranty: 3-Years
devolo dLAN 650 triple+ - Starter Kit - bridge - wall-pluggable
Bridge - 3-port switch (integrated)
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
600 Mbps
Network / Transport Protocol
CSMA/CA
Auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, HomePlug AV
AC 230V (50 Hz)
7.2 cm x 4.1 cm x 14.3 cm
Apple MacOS X 10.6, Ubuntu, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 (32/64 bits), Apple MacOS X 10.8, Ubuntu (64-bit), Apple MacOS X 10.9
English / United Kingdom
3 years warranty
Packaged Quantity
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
600 Mbps
CSMA/CA
Encryption Algorithm
128-bit AES
Status Indicators
Power, link/activity
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
1 x HomePlug AV - power , 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
AC 230V (50 Hz)
5.2 Watt
1 x network cable
Software Included
Drivers & Utilities
7.2 cm
4.1 cm
14.3 cm
Limited warranty - 3 years
10 - 90% (non-condensing)
Scroll to top
