BT.com
Wishlist
Devolo dLAN 650 Triple Plus - Gigabit Ethernet
Devolo dLAN 650 Triple Plus -...
£60.07
£60.07
Add to wishlist
Delivery
Standard Due date unavailable
Faster and more versatile than ever before, the devolo 9231 dLAN 650 Triple+ AV2 HomePlug Adapter is ideal for creating or extending an existing Devolo HomePlug network. Using a households electrical wiring, you can now connect up to three (3) devices that are located away from your router, at speeds up to 600Mbps. Ideal for online gaming, streaming or high bandwidth applications. To create a HomePlug network you will need a minimum of two (2) compatible HomePlug adapters.
Create or upgrade an existing Devolo HomePlug network
Using the AV2 HomePlug standards for speeds up to 600 Mbps
Three (3) integrated 10/100/1000 Gigabit LAN RJ45 Ports
The integrated power socket ensures that no electrical outlet is lost
Optimal Internet connection for computers, televisions and game consoles
Pass-Through Electrical Socket
Featuring a pass-through socket, this devolo 9231 HomePlug Adapter helps reduce any socket loss as electrical devices can be plugged directly in to the power socket on the HomePlugs facia.
3 x Gigabit LAN Ports
With the Gigabit LAN connection, you can connect an Internet-compatible device (e.g. game console, television or media receiver) to the Internet at any time via an Ethernet network cable through either one of the 3 available Gigabit LAN ports.
Standard Warranty: 3-Years
devolo dLAN 650 triple+ - bridge - wall-pluggable
Bridge - 3-port switch (integrated)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
600 Mbps
Network / Transport Protocol
CSMA/CA
Auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, HomePlug AV
AC 230V (50 Hz)
7.2 cm x 4.1 cm x 14.3 cm
Apple MacOS X 10.6, Ubuntu, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 (32/64 bits), Apple MacOS X 10.8, Ubuntu (64-bit), Apple MacOS X 10.9
English / United Kingdom
3 years warranty
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
600 Mbps
CSMA/CA
Encryption Algorithm
128-bit AES
Status Indicators
Power, link/activity
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
1 x HomePlug AV - power , 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
AC 230V (50 Hz)
5.2 Watt
1 x network cable
Software Included
Drivers & Utilities
7.2 cm
4.1 cm
14.3 cm
Limited warranty - 3 years
10 - 90% (non-condensing)
Scroll to top
