BT.com
Wishlist
Devolo DLAN 500 TRIPLE ADA SGL
Delivery
Standard Due date unavailable
Today, the Internet is everywhere: computers, game consoles and consumer electronics devices need a fast and stable Internet connection for work, information and entertainment.
dLAN from devolo is the ideal solution: as fast and easy as a cable network, as flexible as WLAN. The secure networking via the power line makes every power outlet an Internet access point. Now, you can connect even as many as three network-compatible devices to the dLAN 500 AVtriple+, making it ideal for the living room and home offi ce.
The integrated socket ensures that no electrical outlet goes to waste. Setting it up could not be easier - just plug it in, connect the devices, and you're done.
dLAN® 500 - triple the networking performance.
Powerline adapter for connecting up to 3 network-compatible devices
Simple and secure: functions in every room, in every building
Product description
Start your home network with the dLAN® 500 AVtriple+ from devolo. You can connect up to three computers or network-compatible IT devices to this dLAN® adapter. This provides the ideal connection for PC, printer and NAS hard drive, for example. dLAN® 500 provides a transmission rate of 500 Mbps. Automatic data prioritisation ensures that there is no WLAN stutter--all devices are connected with the highest quality. The automatic 128-bit encryption offers maximum security. Moreover, with the integrated electrical socket, the dLAN® 500 AVtriple+ ensures that no power outlet goes to waste, while an integrated mains filter ensures maximum dLAN® performance.
devolo dLAN 500 AVtriple+ - bridge - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
500 Mbps
Network / Transport Protocol
CSMA/CA
Auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901
AC 230V (50/60 Hz) 100 mA
7.2 cm x 4.2 cm x 14.3 cm
248 g
Linux, Apple MacOS X, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista / XP / 7, Microsoft Windows Vista (64-bit versions)
United Kingdom
3 years warranty
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
CSMA/CA
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901, EN55022, EN 60950-1, EN 50412
Status Indicators
Power, link/activity
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, 1024 QAM, 4096 QAM
1 x HomePlug AV - power , 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
AC 230V (50/60 Hz)
Electric Current Required
100 mA
6 Watt
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
7.2 cm
4.2 cm
14.3 cm
248 g
Limited warranty - 3 years
10 - 90% (non-condensing)
Scroll to top
