Click to visit BT.com
BT.com
Wishlist
Devolo dLAN 500 Mini Duo Network Kit
Quicklinx: 8R8VWS00
Mfr#: 9109
Type: Bridge
Speed: 500Mbps
Connectivity: Wired
Pass-through Socket: No
£50.17
Small adapter, twin connection
The ideal entry-level adapter for your home network via the powerline.
Simple and fast connection at powerline speeds up to 500 Mbps.
Two Fast Ethernet LAN connections--use the second LAN port to connect another device simultaneously
Compact and unobtrusive design.
Use the dLAN® 500 duo from devolo for the optimal entrance into your own world of home networking. The easy connection via household powerlines makes the Internet available in any room in no time. Two LAN ports on the adapter allow for two devices to be directly connected, such as a computer and network printer in the home office or Smart TV and a game console in the living room. The compact housing enables flexible and unobtrusive placement at any power outlet in your home. Of course, the home network can be expanded at any time with additional adapters. This way, the innovative dLAN® technology brings the Internet into any room. There are already more than 16 million satisfied devolo customers--the Number 1 for Powerline home networks.
Devolo dLAN 500 duo Network Kit - Network Kit - bridge - wall-pluggable
Bridge
Packaged Quantity
3 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
500 Mbps
Network / Transport Protocol
CSMA/CA
Auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV
AC 230V ( 50/60 Hz )
6.5 cm x 2.9 cm x 8.1 cm
Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
United Kingdom
3 years warranty
Packaged Quantity
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
CSMA/CA
Encryption Algorithm
128-bit AES
Status Indicators
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
LAN : 2 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV
Internal power supply
3.5 Watt
1 x network cable
United Kingdom
6.5 cm
2.9 cm
8.1 cm
3 years warranty
Service & Support Details
Limited warranty - 3 years
10 - 90% (non-condensing)
Devolo dLAN 500 Mini Duo Network Kit Bundle deal on Devolo dLAN 500 Mini Duo Network Kit
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£60.16
Type: Bridge
Speed: 500Mbps
Connectivity: Wired
Brand: Devolo
Price Range Inc VAT: 50 - 100
