BT.com
Wishlist
Devolo dLAN 500 AVmini Network Kit
Delivery
Standard Due date unavailable
The fastest high-speed home network - digital HD entertainment and 3D transmission throughout the home.
  • High transfer rate of up to 500 Mbps
  • For all types of bandwidth-intensive transmission
  • Transmits multiple HDTV streams and even 3D movies reliably throughout the home
  • Full compatibility with all 200AV HomePlug AV adapters
  • Best energy saving mode: consumption is only 0.5 watts in standby mode
  • 3 year manufacturer's warranty, as unit is designed, tested and certified in Germany
HD entertainment and fast home network in one: with speeds of 500 Mbps, the devolo dLAN® 500 AV mini is powerful enough to transmit even 3D movies to every room of your home. Without routing cables or WLAN picture stutter - simply over the electrical wiring. Connect computers, laptops, game consoles as well as Internet TVs and hard drive recorders to each other and to the Internet. The first powerline adapter of the latest generation is fully compatible with all 200 AV adapters, is extremely energy saving and, thanks to its flat, inconspicuous design, can be positioned anywhere.
devolo dLAN 500 AVmini Network Kit - Network Kit - bridge - desktop
Bridge
Packaged Quantity
3 (specifications are for single item)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
500 Mbps
Network / Transport Protocol
CSMA/CA
Auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901
6.6 cm x 2.9 cm x 8 cm
103 g
Linux, Apple MacOS X, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista / XP / 7, Microsoft Windows Vista (64-bit versions)
United Kingdom
3 years warranty
Packaged Quantity
Bridge
Enclosure Type
Desktop
Wired
Data Transfer Rate
500 Mbps
CSMA/CA
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901, EN 60950, EN55022, EN 50412
Status Indicators
Link activity, power
Line Properties
Line Coding Format
64 QAM, 256 QAM, OFDM, 1024 QAM, 4096 QAM
LAN: 1 x HomePlug AV - power , LAN: 1 x 10Base-T/100Base-TX - RJ-45
Internal power supply
5 Watt
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
6.6 cm
2.9 cm
8 cm
103 g
Limited warranty - 3 years
10 - 90% (non-condensing)
Scroll to top
