BT.com
Wishlist
Devolo dLAN 500 AV Wireless+ Starter Kit
Devolo dLAN 500 AV Wireless+...
£119.67
£119.67
Add to wishlist
Delivery
Standard 1-3 working days
dLAN® Powerline adapter for Internet and network connection via household power lines into any room - whether cabled or via WLAN. All devices in the room have an optimum connection
Easy and flexible set-up of WLAN zones - any power outlet is a WLAN access point
3 LAN ports for easily connecting cable-based devices such as PCs, printers, TVs or game consoles
Simple monitoring of the dLAN® home network with adapter status and display of the transmission rate via dLAN® Cockpit App
The integrated electrical socket ensures that no power outlet is lost! You can connect terminal devices and power strips directly to the adapter
Integrated mains filter ensures interference-free data transmission, even when multiple devices are plugged in
500 Mbps (gross) connection for fast data transmission in dLAN® Powerline home network, 300 Mbps (gross) in WLAN operation (IEEE 802.11n standard)
Power outlet adapter with integrated antennas (MiMo arrangement) for optimal transmitting power and flexible positioning
If WLAN is not needed, it can be switched off easily using a switch on the housing. In addition, automatic WLAN time control via software configuration is possible
Encryption for WLAN (WPS, WEP, WPA/WPA2) and dLAN® (AES) at the touch of a button
Thanks to the patented PowerSave technology which reduces the energy consumption automatically
Compatible with all dLAN® 200 and 500 AV adapters (HomePlug AV)
3-year manufacturer´s warranty, as unit is designed, tested and certified in Germany
devolo dLAN 500 AV Wireless+ - Starter Kit - bridge - 802.11a/b/g/n - wall-pluggable
Bridge - 3-port switch (integrated)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
300 Mbps
MAC address filtering, Wi-Fi Protected Setup (WPS), 2T2R MIMO technology
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n
AC 230V
15.2 cm x 7.6 cm x 4 cm
Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
United Kingdom
3 years warranty
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
300 Mbps
Encryption Algorithm
WPA, WPA2, WEP
Status Indicators
Power, WAN, link/activity
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, 1024 QAM, 4096 QAM
LAN: 3 x 10Base-T/100Base-TX - RJ-45 , Antenna: 2 x
Internal power supply
AC 230V
dLAN 500 AVplus Adapter
United Kingdom
15.2 cm
7.6 cm
4 cm
Limited warranty - 3 years
10 - 90% (non-condensing)
Other bundles
£119.67
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£123.15
Scroll to top
