BT.com
Wishlist
Devolo dLAN 500 AV Wireless+
£89.02
£89.02
Add to wishlist
Delivery
Standard Due date unavailable
In the dLAN 500 AV Wireless+, devolo combines all the features of a high-performance Powerline adapter in one housing. It integrated WLAN for an optimal connection to wireless terminal devices such as a smartphone or laptop, three LAN ports for connecting network-compatible devices. Using the integrated electrical socket, power strips and other devices up to 16 amps can be connected. Never has it been easier, faster or more secure to network wireless and stationary devices!
devolo dLAN 500 AV Wireless+ - bridge - 802.11a/b/g/n - wall-pluggable
Bridge - 3-port switch (integrated)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
Frequency Band
2.4 GHz / 5 GHz
Network / Transport Protocol
CSMA/CA
Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wi-Fi Protected Setup (WPS), integrated power socket, 2T2R MIMO technology, Direct Sequence Spread Spectrum (DSSS)
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, HomePlug AV
AC 230V (50 Hz)
7.6 cm x 4 cm x 15.2 cm
Apple MacOS X, Microsoft Windows Vista / XP / 7, Ubuntu, Microsoft Windows Vista / XP / 7 (64-bit versions), Windows 8 (32/64 bits), Windows 8 Pro, Windows 8 Pro 64-bit Edition
United Kingdom
3 years warranty
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Max Range Open Space
300 m
CSMA/CA
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, 128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, HomePlug AV, FCC Class B certified, R&TTE, WEEE
Status Indicators
Power, wireless, link/activity
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, 1024 QAM, 4096 QAM
1 x HomePlug AV - power CEE 7/7 (SCHUKO) , LAN: 3 x 10Base-T/100Base-TX - RJ-45 , Antenna: 2 x
Internal power supply
AC 230V (50 Hz)
9 Watt
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
7.6 cm
4 cm
15.2 cm
Limited warranty - 3 years
10 - 90% (non-condensing)
Other bundles
£89.02
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£92.50
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
2* Units Failed
Reviewed by Andy on 17/07/2013
I purchased 3 of these units in July 2012, all 3 have failed. BT replaced 2 of them. But the 3rd was a week out of the 12 month period and I'm having to return directly to Devolo.
I have been totally happy with the units while they worked, just let down with the quality.
Scroll to top
