BT.com
Wishlist
Devolo dLAN 200 AV Wireless N Single Adapter (HomePlugAV)
Delivery
Standard Due date unavailable
One for all! Powerline adapter with integrated WLAN access point and three LAN ports
Game consoles, Internet TV sets, Blu-ray players, laptops and smartphones - more and more devices can be connected to the Internet. Whether using WLAN or a classic network cable - the dLAN® 200 AV Wireless N is the solution. Using the compact devolo adapter, you can easily set up individual WLAN zones in the home and also connect up to three cable-based devices in the room to the Internet using just one dLAN® adapter. Ideal for the living room and home office!
devolo dLAN 200 AV Wireless N - bridge - 802.11b/g/n - wall-pluggable
Bridge - 3-port switch (integrated)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, ARP, DHCP, CSMA/CA, CSMA/CD
Remote Management Protocol
HTTP
Auto-uplink (auto MDI/MDI-X), Wi-Fi Protected Setup (WPS), integrated power socket
IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1D, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n, HomePlug AV
6.8 cm x 4.9 cm x 11 cm
200 g
Linux, Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions)
United Kingdom
3 years warranty
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Max Range Open Space
300 m
HTTP
Encryption Algorithm
AES, TKIP, WPA, WPA2, 128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1D, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n, HomePlug AV, EN55022, EN55024, EN 300.328, EN 60950-1, WEEE, EN 300.489.1
Built-in Devices
Radio access point
Status Indicators
Power, WLAN, LAN, link/activity
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM
LAN: 1 x HomePlug AV - power , LAN: 3 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
Internal
Antenna Qty
2
Internal power supply
7 Watt
United Kingdom
Software Included
Drivers & Utilities
6.8 cm
4.9 cm
11 cm
200 g
Limited warranty - 3 years
10 - 90% (non-condensing)
Resources
The following resources are available for the Devolo dLAN 200 AV Wireless N Single Adapter (HomePlugAV)
Scroll to top
