BT.com
Wishlist
Devolo dLAN® Powerline 550 Duo+ Pair
Devolo dLAN® Powerline 550 Duo+...
£78.82
2 in stock
£78.82
Add to wishlist
Delivery
Standard 3-5 working days
Connecting the best together.
The dLAN® 550 duo+ is here. In its smart design, it conceals the most innovative Powerline technology and makes your home network even easier and more multimedia-based. The fast transfer rate and powerline speeds up to 500 Mbps allow you to experience entertainment at the highest level. The range+ technology provides an even more stable Internet connection with significantly longer range.
Enjoy even more stability and mobility throughout the home. Herewith, no power socket is lost: dLAN® 550 duo+ comes with an integrated electrical socket and also offers two Fast Ethernet ports for two terminal devices. Experience the best options for your Internet with dLAN® 550 duo+ from devolo.
Your home network from the power socket. Unpack. Plug it in. Get started. The easy way to connect using your home power lines. Turn any power socket into an Internet access point.
Even higher performance and longer range with range+ technology.
The optimal Internet connection for computers, televisions and game consoles. No signal loss - stable and continuous.
Installation as easy as childs play. Just unpack it, plug it in and get started.
The two Fast Ethernet LAN ports allow you to connect two Internet-compatible devices (e.g. a game console, television or media receiver) to the Internet at any time via network cable.
With the integrated electrical socket, no power socket in your room is lost.
Rely on the Number 1 - Join the more than 10 million satisfied devolo dLAN® customers around the world.
3-year manufacturer`s warranty.
With two LAN ports for connecting network-compatible devices and the integrated power outlet, this is an ideal entry-level adapter for your home network.
devolo dLAN 550 duo+ - Starter Kit - bridge - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
500 Mbps
Integrated power socket
Apple MacOS X 10.6, Microsoft Windows 7 Home Premium (32/64 bits), Ubuntu 12.04, Windows 8 (32/64 bits), Windows 8 Pro (32/64 bits)
United Kingdom
3 years warranty
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
Status Indicators
LAN: 2 x 10Base-T/100Base-TX - RJ-45
Internal power supply
2 x network cable
United Kingdom
Limited warranty - 3 years
10 - 90% (non-condensing)
Other bundles
£78.82
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£82.30
Scroll to top
