BT.com
Wishlist
Devolo dLAN® 500 WiFi Network Kit
Delivery
Standard 1-3 working days
Wi-Fi, wherever you want it
The perfect combination: dLAN® powerline technology and Wi-Fi
Finally, full-strength reception for smartphones and tablets Including one-of-a-kind WiFi Move Technology Integrated fast Ethernet connection Compact and unobtrusive design
dLAN® 500 WiFi technology combines the latest technology and unobtrusive design with the best Internet connection. As a Powerline adapter, the dLAN® 500 WiFi uses internal power lines as a long cable, thereby bringing the Internet to any room.
The integrated wireless LAN also provides complete Internet coverage to every nook and cranny. Smartphones, tablets and laptops have full-strength coverage right from the start without any problems.
An additional terminal device can be connected at any time (such as a Smart TV or game console) using the additional fast Ethernet connection.
Intelligent WiFi Move Technology provides even more freedom: Now, smartphones, tablets and laptops are automatically connected to the Internet - the best Wi-Fi reception in any room or floor automatically! And the compact and unobtrusive design can be integrated into any residential interior without looking out of place. The dLAN® 500 WiFi from devolo brings the future to your home.
Devolo dLAN 500 WiFi Network Kit - Network Kit - bridge - 802.11b/g/n - wall-pluggable
Bridge
Packaged Quantity
3 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
Frequency Band
2.4 GHz
Data Transfer Rate
500 Mbps
Network / Transport Protocol
CSMA/CA
Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wi-Fi Protected Setup (WPS)
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, HomePlug AV, IEEE 1901
AC 230V ( 50 Hz )
6.8 cm x 4.1 cm x 6.8 cm
Linux, Apple MacOS X, Android, Apple iOS, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
United Kingdom
3 years warranty
Packaged Quantity
Bridge
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
500 Mbps
Max Range Open Space
300 m
CSMA/CA
Encryption Algorithm
WPA, WPA2, 128-bit AES, WEP
Status Indicators
WLAN, link/activity
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, 1024 QAM, 4096 QAM
LAN: 1 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV , Antenna: 1 x
Internal power supply
AC 230V ( 50 Hz )
5 Watt
1 x network cable
United Kingdom
6.8 cm
4.1 cm
6.8 cm
Limited warranty - 3 years
10 - 90% (non-condensing)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Pricey Powerline that Works
Reviewed by Mr G on 31/01/2014
It works and it works well. Probably one of the priciest powerline kits I've seen but I think you're paying for what you get. The quality is good, the speed is better than I'd hoped for in my old house with its old wiring (pushing 100 Mb/s in places). The ability to spin up a guest network is handy.
I have four of these spead over the three floors of my house and having more than the minimum two units definitely added stability and upped average transfer rates.
The instructions are unnecessarily complicated. Sixty pages of waffle when all you really need to do is plug one end into your router. Press the house button, then plug the other end into the target power socket and press its house button.
Overall: premium product but a premium price.
Scroll to top
