BT.com
Wishlist
Devolo 9423 Wi-Fi range extender
£34.62
6 in stock
£34.62
Add to wishlist
Delivery
Standard 3-5 working days
The easy way to increase Wi-Fi range!
Simply plug in, start surfing and have fun!
Easily and quickly boosts the range of your available Wi-Fi network.
Integrated Fast Ethernet LAN port for an additional terminal device (Smart TV, game console, computer etc.).
Multi-tier, visual signal strength display directly on the device.
Compact design - versatile positioning throughout your house.
Compatible with all current Wi-Fi routers* thanks to 802.11n standard.
Rely on the number 1: There are already over 10 million satisfied devolo dLAN® customers worldwide.
3-year manufacturer´s warranty.
*Wi-Fi routers supporting WPS push-button pairing
devolo WiFi Repeater - Wi-Fi range extender
External
United Kingdom
Ralink
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Microsoft Windows 7 (32/64 bits), Android 2.3, Windows 8 (32/64 bits), Windows 8 Pro (32/64 bits), Apple iOS 7, Apple MacOS X 10.6 - 10.9, Android 4.4 (KitKat), Ubuntu 14.04, Android 4.0 - 4.2, Ubuntu 15.04, Ubuntu 15.10, Apple iOS 8
10.5 cm x 5.8 cm x 4.2 cm
3 years warranty
10.5 cm
5.8 cm
4.2 cm
Enclosure Colour
White
United Kingdom
Processor / Memory / Storage
Processors Installed
Ralink
External
Wireless, wired
Data Transfer Rate
300 Mbps
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz
Max Range Open Space
300 m
Selectable Channels Qty
13
Status Indicators
WLAN
Auto-uplink (auto MDI/MDI-X), Wi-Fi Protected Setup (WPS), 2T2R MIMO technology
Encryption Algorithm
WPA, WPA2
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
2
1 x 100Base-TX - RJ-45
Internal power supply
3 Watt
Limited warranty - 3 years
10 - 90% (non-condensing)
Other bundles
£34.62
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£38.10
Scroll to top
