BT.com
Wishlist
Devolo 9378 dLAN powerline 1200+ Starter Kit
Devolo 9378 dLAN powerline 1200+...
£109.98
1200mbps - Our Fastest Powerline Ever!
£109.98
Add to wishlist
Delivery
Standard 1-3 working days
dLAN® 1200+ from devolo - for the first time, transmit data easily over the power line at speeds up to 1.2 gigabits per second!
Fast, economical, easy
With transmission rates extending into the gigabit range, devolo opens up a new dimension in Powerline communication. The dLAN 1200+ with 1.2 Gbps is not only the fastest but also the most stable dLAN adapter with the widest coverage of all time thanks to range+ Technology including MIMO. The best possible quality of broadband Internet is thus available at every power outlet of the home.
Furthermore, the devolo engineers have been successful in lowering the adapter's power consumption, despite doubling the speed. When operating, the dLAN 1200+ uses a maximum of 4.2 watts. If the connected terminal device is switched off, the adapter also automatically goes into standby mode and saves even more energy working with 0.7 watts.
One thing about the dLAN 1200+ has not changed, and for good reason: installation is still as easy as you would expect from devolo. One adapter is connected to the router using the Ethernet cable provided and plugged into a nearby power outlet. The user follows a similar procedure to connect the second one to the terminal device and the network connection is already available. devolo recommends also activating the 128-bit AES encryption by touching the button. This makes unauthorised access to the network even more difficult.
Gigabit Ethernet and integrated electrical socket with child-safety features
To live up to the high performance of the Powerline chip, the dLAN 1200+ is equipped with a gigabit Ethernet connection. A corresponding gigabit Ethernet cable is provided with every dLAN 1200+.
For additional performance optimisation, the adapter has an integrated electrical socket. This provides the advantage of no power outlet going to waste for the user. Furthermore, the integrated electrical socket is equipped with a high-performance mains filter that reliably prevents possible interference from other devices connected to the mains circuit. For maximum security, the integrated electrical socket also has a child-safety feature.
Compatible with dLAN 200, 500 and 650, availability and price
The new devolo dLAN 1200 generation is fully compatible with all dLAN 200, dLAN 500 and dLAN 650 models and additional Powerline adapters in accordance with the HomePlug AV(2) standard. The sales launch will take place in September 2014. The adapter can also be used as a Starter Kit for setting up a home network and as an individual device for adding to an existing Powerline installation.
Contains 2 units
Devolo dLAN 1200+ - Starter Kit - bridge - wall-pluggable
Bridge
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
1200 Mbps
Network / Transport Protocol
CSMA/CA
Auto-uplink (auto MDI/MDI-X), integrated power socket
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, HomePlug AV, IEEE 802.3az
AC 230V (50 Hz)
6.6 cm x 4.2 cm x 13 cm
Linux, Apple MacOS X 10.6 or later, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
3 years warranty
Packaged Quantity
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
1200 Mbps
CSMA/CA
Encryption Algorithm
128-bit AES
Status Indicators
Power, link/activity
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
1 x HomePlug AV - power , 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
AC 230V (50 Hz)
4.5 Watt
1 x network cable
6.6 cm
4.2 cm
13 cm
Limited warranty - 3 years
10 - 90% (non-condensing)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Speed Indeed
Reviewed by Anonymous on 02/10/2014
Now get 680 MPS got 290 MPS on the 500 series - that's a great leap for my system.
5* devolo 9378 power line 1200+ starter kit
Reviewed by Stuart Dixon on 06/10/2014
Just got mine - a doodle to set up - have downloaded Devolo Cockpit for Mac OSX and I am getting 1110 Mbits/sec - very impressed. Only downside - Devolo include Cat 5e cable - so buy your own better quality Cat 6 as the hardware will do its best with the correct speed rated cable. Thanks Dunc at BT Commercial Team for sorting out the problems in finally getting it us.
Our response
Pleasure Stuart, glad we got it sorted in the end! Thanks, Dunc
Scroll to top
