BT.com
Wishlist
Dell XPS 13 9360 i7 7660U/2.5GHz Win10Pro 64-bit 16gb 512GB 13.3"
Delivery
Standard Due date unavailable
The smallest 13.3" (33.8cm) laptop on the planet has the world's first virtually borderless InfinityEdge display - available with touch.
More screen, less to carry: The virtually borderless InfinityEdge display maximizes screen space by squeezing a 13" (33 cm) display in an 11" (28 cm) frame. With a bezel only 5.2 mm thin, starting at only 1.22kg and measuring a super slim 9-15 mm, the XPS 13 is exceptionally thin and light.
Stunning UltraSharp QHD+ resolution (3200x1800): An optional upgrade gives you eye-popping detail with 5.7 million pixels (276 ppi).
Easy to share: See content clearly from nearly every angle with the IGZO IPS panel, providing a wide viewing angle of up to 170°.
Brighten your day: 400 nit brightness is brighter than a typical laptop panel, so you get a great view, even outside.
Gorgeous colors: See the brightest brights and the darkest darks with a color gamut of 72% and a contrast ratio of 1000:1.
Touch friendly: Tap, swipe and pinch your way around the screen. The optional touch display lets you interact naturally with your technology.
The latest performance features: New next gen Intel Core processors and higher performing graphics offer speed and reliability. Boot and resume in seconds with the latest solid state drives now with faster PCIe options up to 1TB3 and 16GB4 of memory.
Stay powered longer: Depending on how you use your laptop, your battery life will vary. When you are using productivity applications, like Word or Excel, experience the longest battery life of any 13-inch with up to 22 hours5 of continual use6 on a FHD model. Enjoy up to 13 hours of battery life when streaming Netflix7 content or browsing the web with Microsoft Edge8. Add an additional 11 hours, 30 minutes with the optional Dell Power Companion59.
Leading-edge connectivity: The Thunderbolt 3 multi-use Type-C port allows you to charge your laptop, connect to multiple devices (including support for up to two 4K displays) and enjoy data transfers up to 40Gbps, 8 times that of a USB 3.010.
Advanced docking: The XPS 13 can be used with the newest Dell docking solutions, featuring single-cable connections for power, Ethernet, audio and video.
Killer Wireless: The Killer 1535 Wireless-AC adapter provides the strongest and most reliable Wi-Fi connection and was designed specifically to make your online videos, voice and games play faster and smoother. It automatically detects, classifies and prioritizes network traffic ensuring your most important data takes priority over your other less urgent applications. Killer delivers your critical packets immediately, thus eliminating unnecessary latency and lag.
What's in the box
  • Dell XPS 13 9360
  • 4-cell battery
  • Power adapter
Dell XPS 13 9360 - 13.3" - Core i7 7660U - 16 GB RAM - 512 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (7th Gen) 7660U / 2.5 GHz (4 GHz) / 4 MB Cache
16 GB LPDDR3 (provided memory is soldered)
Storage
512 GB - M.2 SSD
Optical Drive
No optical drive
Display
13.3" touchscreen 3200 x 1800 / QHD+
Graphics
Intel Iris Plus Graphics 640
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
4-cell
Silver
30.416 cm x 20.025 cm x 1.535 cm
1.29 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 1 year - response time: next business day
Bundled Services
1 Year Dell ProSupport
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Bundled Services
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
16 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
512 GB SSD - (M.2) PCIe
Display
13.3"
Touchscreen
Resolution
3200 x 1800 (QHD+)
Widescreen
UltraSharp, Infinity Edge display
Audio & Video
Graphics Processor
Camera
Resolution
0.92 Megapixel
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Sound
Stereo speakers, two microphones
Codec
Realtek ALC3246
Audio Features
MaxxAudio
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Killer Wireless-AC 1535
4-cell Lithium Ion
60 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V, 2.31 A
Connections & Expansion
USB 3.0 , USB 3.0 (PowerShare) , USB-C Gen 2/Thunderbolt 3 , Headphone/microphone combo jack
Memory Card Reader
3 in 1 (SD Card, SDHC Card, SDXC UHS Card)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Silver
Battery life Indicator
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.29 kg
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
140 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
Scroll to top
