BT.com
Wishlist
Dell X1052P Switch L2+ Managed 48 x 10/100/1000 4 x10 GigabitSFP+
Dell X1052P Switch L2+ Managed 48 x...
£829.22
£829.22
Add to wishlist
Delivery
Standard 1-3 working days
Easily manage your office network with 1GbE and 10GbE switches that offer enterprise-class features and intuitive, GUI-based management.
Dell Networking X1052P - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L2+ - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
360 W
Performance
Switching fabric bandwidth: 176 Gbps , Forwarding performance: 131 Mpps
MAC addresses: 16000 , LAG groups: 12 , Priority queues per port: 8 , Virtual interfaces (VLANs): 4096 , Maximum member ports per LAG: 8
MAC Address Table Size
16K entries
Remote Management Protocol
SNMP 1, SNMP 2, RMON, SNMP 3, HTTP, CLI
Auto-negotiation, VLAN support, Syslog support, port mirroring, Broadcast Storm Control, IPv6 support, SNTP support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Cable Test (VCT) technology, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Uni-Directional Link Detection (UDLD), DNS server, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), SNMP trap, static routing, GARP VLAN Registration Protocol (GVRP), SNMP support, ARP inspection, Head of Line Blocking Prevention, Back Pressure Support, Proprietary Protocol Filtering
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP)
43.4 cm x 40.7 cm x 43.5 cm
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
360 W
Performance
16K entries
Authentication Method
RADIUS, TACACS+
48 x 1000Base-T 12 ports (PoE+) / 24 ports (PoE) , 4 x 10Gbit LAN SFP+ , 1 x USB Type A management , 1 x micro-USB management
Internal power supply
Power Provided
525 Watt
82 Watt
43.4 cm
40.7 cm
43.5 cm
Limited warranty - lifetime
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Accessories
£3.80
£13.52
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.31
£53.67
Scroll to top
