BT.com
Wishlist
Dell X1052 Switch L2+ Managed 48 x 10/100/1000 4 x 10 GigabitSFP+
Dell X1052 Switch L2+ Managed 48 x...
£485.32
£485.32
Add to wishlist
Delivery
Standard 1-3 working days
The intuitive graphical user interface (GUI) of Dell Networking X-series switches makes setup and management simple for network administrators. Based on extensive usability testing, the design of everything from navigation to menu structures and help tips is inspired by the way IT professionals think and work, making the interface a pleasure to use regularly or occasionally.
Pick the right switch for your network. Choose from a broad selection of models with rich feature sets and a variety of port counts. Power over Ethernet (PoE) and PoE+ models provide additional deployment flexibility, allowing you to connect, auto-configure and power phones, cameras, compact switches and other network devices.
Dell Networking X1052 - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L2+ - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x 10 Gigabit SFP+
Performance
Switching fabric bandwidth: 176 Gbps , Forwarding performance: 131 Mpps
MAC addresses: 16000 , LAG groups: 12 , Priority queues per port: 8 , Virtual interfaces (VLANs): 4096 , Maximum member ports per LAG: 8
MAC Address Table Size
16K entries
Remote Management Protocol
SNMP 1, SNMP 2, RMON, SNMP 3, HTTP, CLI
Auto-negotiation, VLAN support, Syslog support, port mirroring, Broadcast Storm Control, IPv6 support, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Cable Test (VCT) technology, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Uni-Directional Link Detection (UDLD), DNS server, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), SNMP trap, static routing, GARP VLAN Registration Protocol (GVRP), SNMP support, ARP inspection, Head of Line Blocking Prevention, Back Pressure Support, Proprietary Protocol Filtering
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP)
43.4 cm x 27 cm x 43.5 cm
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Authentication Method
RADIUS, TACACS+
48 x 1000Base-T , 4 x 10Gbit LAN SFP+ , 1 x USB Type A management , 1 x micro-USB management
Internal power supply
Power Provided
100 Watt
75 Watt
43.4 cm
27 cm
43.5 cm
Limited warranty - lifetime
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Accessories
£3.80
£13.52
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.31
£53.67
Scroll to top
