BT.com
Wishlist
Dell X1008 Switch L2+ Managed 8 x 10/100/1000
Dell X1008 Switch L2+ Managed 8 x...
£136.54
Hurry, only 3 left in stock!
£136.54
Add to wishlist
Delivery
Standard 1-3 working days
Easily manage your office network with 1GbE and 10GbE switches that offer enterprise-class features and intuitive, GUI-based management.
Dell Networking X1008 - switch - 8 ports - Managed
Switch - 8 ports - L2+ - Managed
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Switching fabric bandwidth: 16 Gbps , Forwarding performance: 11.9 Mpps
MAC addresses: 16000 , LAG groups: 12 , Priority queues per port: 4 , Virtual interfaces (VLANs): 4096 , Maximum member ports per LAG: 8
MAC Address Table Size
16K entries
Remote Management Protocol
SNMP 1, SNMP 2, RMON, SNMP 3, HTTP, CLI
Auto-negotiation, VLAN support, Syslog support, port mirroring, Broadcast Storm Control, IPv6 support, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Cable Test (VCT) technology, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Uni-Directional Link Detection (UDLD), DNS server, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), SNMP trap, static routing, GARP VLAN Registration Protocol (GVRP), SNMP support, ARP inspection, Head of Line Blocking Prevention, Back Pressure Support, Proprietary Protocol Filtering
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP)
15.113 cm x 15.113 cm x 42.5 cm
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
16K entries
Authentication Method
RADIUS, TACACS+
8 x 1000Base-T , 1 x USB Type A management , 1 x micro-USB management
External power adapter
Power Provided
24 Watt
9.7 Watt
PoE powered
15.113 cm
15.113 cm
42.5 cm
Limited warranty - lifetime
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Accessories
£3.80
£13.52
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.31
£53.67
Scroll to top
