BT.com
Wishlist
Dell Wyse Z90D7 Thin Client - DTS - 1 x G-T56N RAM 4GB Flash 16GB
Last Few Remaining
Clearance
Delivery
Standard Due date unavailable
Wyse Z90D7 is a super high-performance thin client for virtual desktop environments. Featuring a revolutionary, unified engine that eliminates performance constraints, the Z90D7 achieves incredible speed and power for the most demanding applications, rich graphics and HD video. Take a unit from box to productivity in minutes. The Z90D7 is an ideal thin client for the most demanding mix of virtual desktop or cloud applications.
Dell Wyse Z90D7 Thin Client - DTS - G-T56N 1.65 GHz - 4 GB - 16 GB
Thin client - desktop slimline
1 x AMD G-T56N 1.65 GHz (Dual-Core)
RAM
4 GB DDR3 SDRAM
Hard Drive
Flash 16 GB
Graphics Controller
AMD Radeon HD 6320
Audio Output
Stereo - integrated
GigE
OS Provided
Microsoft Windows Embedded Standard 7
4.7 cm x 22.5 cm x 20 cm
1.12 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
3 years warranty
Thin client
Product Form Factor
Desktop slimline
Built-in Devices
Speaker
Processor / Chipset
CPU
AMD G-T56N 1.65 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
4 GB
DDR3 SDRAM
Hard Drive
Flash
16 GB
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon HD 6320
Video Interfaces
VGA, DVI, DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
48 kHz
Integrated
1 x DisplayPort , 1 x DVI-I , 1 x VGA (with adapter) , 4 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out (1 in front) , 1 x microphone (1 in front) , 2 x serial , 1 x parallel , 1 x PS/2 keyboard
Vertical stand
DVI-VGA adapter
Theft/Intrusion Protection
FCC Class B certified, TUV GS, VCCI, C-Tick, ISO 9241-3, ISO 9241-8, EN 60950, UL 60950, RoHS, WEEE
Power adapter
Nominal Voltage
Operating System / Software
OS Provided
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 3 years
4.7 cm
22.5 cm
20 cm
1.12 kg
10 °C
10 - 95% (non-condensing)
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£40.22
£24.72
£9.80
£20.37
£18.12
£13.87
Scroll to top
