BT.com
Wishlist
Dell Wyse P25 Class Dual VESA Mounting Bracket Kit
Delivery
Standard Due date unavailable
The bracket enables a cloud client to be mounted to a wall or on most VESA compliant mounting surfaces and monitors. Both VESA 75 mm and 100 mm mounting patterns are supported. The mounting bracket consists of two pieces. The large bracket piece attaches to the mounting surface using the VESA mounting patterns. The cloud client is inserted in a vertical position and cables are attached. The smaller bracket piece attaches to the VESA compliant mounting monitor. The monitor-bracket and mounted wall-bracket pieces are then joined with the provided four thumb screws.
Dell Wyse P25 class dual VESA mounting bracket kit - thin client to monitor mounting kit
Thin client to monitor mounting kit
Placing / Mounting
Wall mountable
Dell Wyse P25, T10 Thin Client
Placing / Mounting
Wall mountable
Scroll to top
