BT.com
Wishlist
Dell Wyse D90D7 Thin Client 4GB 16GB
Delivery
Standard Due date unavailable
The Dell Wyse D90D7 is a high-performance thin client for virtual desktop environments. Featuring an unified engine that eliminates performance constraints, the D90D7 achieves outstanding speed and power for the most demanding VDI and embedded Windows applications, rich graphics and HD video. Take a unit from box to productivity in minutes. Just select the desired configuration and the D90D7 does the rest automatically - no need to reboot. The D90D7 is an ideal thin client for demanding virtual desktop or cloud applications.
Dell Wyse D90D7 Thin Client - DTS - G-T48E 1.4 GHz - 4 GB - 16 GB
Thin client - desktop slimline
1 x AMD G-T48E 1.4 GHz (Dual-Core)
RAM
4 GB (installed) / 4 GB (max) - DDR3 SDRAM
Hard Drive
Flash 16 GB
Graphics Controller
AMD Radeon HD 6250
Audio Output
Stereo - integrated
GigE
OS Provided
Microsoft Windows Embedded Standard 7
4 cm x 18.5 cm x 17 cm
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Thin client
Product Form Factor
Desktop slimline
Built-in Devices
Speaker
Processor / Chipset
CPU
AMD G-T48E 1.4 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
4 GB / 4 GB (max)
DDR3 SDRAM
Effective Memory Speed
1066 MHz
Hard Drive
Flash
16 GB
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon HD 6250
Video Interfaces
VGA, DVI, DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
Integrated
1 x DVI-I , 4 x USB 2.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x headphones , 1 x VGA (with adapter) , 1 x DisplayPort
Vertical stand
DVI-VGA adapter
Theft/Intrusion Protection
FCC Class B certified, TUV GS, VCCI, C-Tick, ISO 9241-3, ISO 9241-8, EN 60950, UL 60950, RoHS, WEEE, cULus, EuP
Power adapter
Nominal Voltage
Power Provided
65 Watt
Operating System / Software
OS Provided
ENERGY STAR Certified
Limited warranty - 3 years
4 cm
18.5 cm
17 cm
10 °C
10 - 95% (non-condensing)
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£40.22
£24.72
£9.80
£20.37
£18.12
£13.87
Scroll to top
