BT.com
Wishlist
Dell UltraSharp UP2516D 25" 2560x1440 6ms HDMI DisplayPort USB IPS LED Monitor
Delivery
Standard 1-3 working days
Expect vivid, accurate color precision, ultrathin bezels and the widest color coverage to suit your professional needs with the Dell UltraSharp 25 monitor with PremierColor.
Dell UltraSharp UP2516D - LED monitor - 25" - with 3-Years Advance Exchange Service
LED-backlit LCD monitor - 25"
Energy Class
Class C
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.216 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
6 ms
Colour Support
1.07 billion colours
Input Connectors
2xHDMI (MHL), DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
56.77 cm x 20.03 cm x 39.8 cm
6.65 kg
Microsoft Certification
Compatible with Windows 7
Plug and Play, DDC/CI, RoHS, TCO Displays, BC1.2
3 years warranty
Bundled with
Display Type
Energy Class
Class C
Diagonal Size
25"
Viewable Size
25"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.216 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 88 kHz
Video Bandwidth
241.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 10000K
Controls & Adjustments
Brightness, contrast, sharpness, saturation, gamma correction, input select, colour temperature, hue, aspect control, colour space, gain, offset
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Picture in picture, picture by picture, PremierColor technology, 100% sRGB colour gamut, 99% Adobe RGB colour gamut, stand lock, Multi-Stream transport (MST), adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Premium Panel Guarantee, arsenic-free glass, Factory Calibration Report, 98% DCI-P3, 100% Rec 709 colour gamut
56.77 cm x 20.03 cm x 39.8 cm - with stand
6.65 kg
Bundled with
DisplayPort , Mini DisplayPort , 2 x MHL / HDMI , 4 x USB 3.0 downstream (Type A) , 2 x USB 3.0 upstream (Type B) , DisplayPort output , Audio line-out
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, portrait / landscape mode, VESA interface support, Dell Soundbar mounting slots
1 x SuperSpeed USB cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m
130 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 56.77 cm - depth: 20.03 cm - height: 39.8 cm - weight: 6.65 kg , Without stand - width: 56.77 cm - depth: 5.16 cm - height: 33.79 cm - weight: 4.1 kg
Limited warranty - 3 years
35 °C
10 - 80% (non-condensing)
Accessories
£9.99
£6.94
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.78
£36.49
£49.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£56.07
£17.48
Scroll to top
