BT.com
Wishlist
Dell Ultrasharp U2713H 27" 2560x1440 6ms DVI DisplayPort HDMI LED Monitor
Delivery
Standard Due date unavailable
Enjoy excellent performance, connectivity, picture quality with enhanced clarity on UltraSharp U2713H 27-inch widescreen flat panel monitor from Dell. The dynamic contrast ratio of 2 million: 1 provides to work in razor-sharp clarity and experience smooth, jitter-free moving images. Get extreme screen clarity and rich images with a WQHD 2560 x 1440 at 60 Hz resolution with a color depth of 1.07 billion colors. Additionally, high response time of 6 ms designed to reduce ghosting and deliver razor sharp images. Enjoy exceptional image quality and color conformity with DVI-D (HDCP). You can easily Plug and Play with the four USB connectors. Be assured of reliable office performance and user comfort with the unique combination of energy-conscious and environmentally sound design of U2713H. Thanks to the lower power consumption with LED technology, PowerNap and Dynamic Dimming, you can also see potential cost savings over time!
The U2713H is designed to comply with the energy-efficiency standards, including ENERGY STAR, EPEAT Gold, TCO certified displays and CEL compliant. Additionally, the EPEAT Gold rating on the U2713H helps ensure that your organization stays aligned with the highest environmental standards. With all such impressive features and more, the U2713H is an ideal choice for your smart and modern lifestyle!
Dell UltraSharp U2713H - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
66 kWh
Power Consumption (On mode)
45 W
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.231 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
63.93 cm x 20.05 cm x 42.34 cm
United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
TCO Displays
Display Type
Energy Class
Class C
66 kWh
45 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.231 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, PremierColor technology, 100% sRGB colour gamut, 99% Adobe RGB colour gamut, stand lock, integrated cable management, 120% (CIE 1976) colour gamut
63.93 cm x 20.05 cm x 42.34 cm - with stand
DVI-D (dual link) (HDCP) , 2 x DisplayPort , HDMI , Mini DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
Flat Panel Mount Interface
Security lock slot (cable lock sold separately), integrated cable management
Stand, cable tie
1 x USB cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x DVI cable
TCO Displays
United Kingdom
Power Supply
Internal
60 Watt
On / Off Switch
No
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 63.93 cm - depth: 20.05 cm - height: 42.34 cm , Without stand - width: 63.93 cm - height: 37.82 cm - weight: 6.3 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
10 - 80% (non-condensing)
Accessories
£9.99
£6.87
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.73
£35.97
£48.72
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.27
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
2* Not suitable for Mac Users
Reviewed by Mark Price on 03/08/2015
The hardware calibration tool that Dell provide for this monitor is not compatible with Mac OSX - it's not suitable for that operating system. There is a green tint in the monitor generally which probably can be removed if you can hardware calibrate it. If you can't, this product is not good for those carrying out photographic or design work. Software calibration with a colorimeter hasn't worked well for me, so I'd recommend buying from someone else if you want a high quality monitor.
Scroll to top
