BT.com
Wishlist
Dell UltraSharp U2515H 25" 2560x1440 8ms HDMI DP USB 2K Monitor
Delivery
Standard Due date unavailable
Bring your work to life in vivid color detail, sharp QHD resolution and extensive connectivity for outstanding usability. Superior screen clarity meets complete color precision for a brilliant viewing experience.
Work the way you want. Position your monitor for ultimate comfort with a full range of tilt, pivot, swivel and height adjustments along with easy connections to your PC and peripherals.
Made with eco-friendly materials, the U2515H is BFR/PVC-free (excluding external cables) and has arsenic-free glass and a mercury-free LED panel.
Dell UltraSharp U2515H - LED monitor - 25"
LED-backlit LCD monitor - 25"
Energy Class
Class B
Energy Consumption per Year
41 kWh
Power Consumption (On mode)
28 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Pixel Pitch
0.216 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
19 ms (On/Off); 6 ms (grey-to-grey)
Colour Support
16.8 million colours
Input Connectors
2xHDMI, 2xMHL, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
56.9 cm x 20.5 cm x 39.8 cm
6.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VESA EDID, DDC/CI, NFPA 99, TCO Displays
Display Type
Energy Class
Class B
41 kWh
28 W
Diagonal Size
25"
Viewable Size
25"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.216 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 86 Hz
Horizontal Refresh Rate
30 - 113 kHz
Video Bandwidth
241.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 5000K, 6500K, 7500K, 10000K, 5700K
Controls & Adjustments
Brightness, contrast, sharpness, saturation, gamma correction, rotation, input select, colour temperature, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
LED edgelight system, stand lock, 99% sRGB colour gamut, Multi-Stream transport (MST), BFR/PVC-free, Energy Gauge, Energy Saver, Mercury free, 91% (CIE 1976) colour gamut, 76% (CIE 1931) colour gamut, Factory Calibration, High Bit Rate 2 (HBR2), Transition Minimised Differential Signaling (TMDS) technology, backlight dimming control
56.9 cm x 20.5 cm x 39.8 cm - with stand
6.5 kg
USB 3.0 upstream , 5 x USB 3.0 downstream , DisplayPort , Mini DisplayPort , 2 x MHL / HDMI , DisplayPort output (MST) , Audio line-out
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
115 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, 1 USB 3.0 charging port, Dell Soundbar mounting slots
Stand, cable management cover
1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable
Power Supply
Internal
87 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 56.9 cm - depth: 20.5 cm - height: 39.8 cm - weight: 6.5 kg , Without stand - width: 56.9 cm - depth: 4.64 cm - height: 33.87 cm - weight: 4.4 kg
ENERGY STAR Certified
10 - 80% (non-condensing)
Accessories
£9.99
£6.87
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.73
£35.97
£48.72
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.27
Scroll to top
