Click to visit BT.com
BT.com
Wishlist
Dell UltraSharp U2413 24" 1920x1200 6ms DVI-D HDMI DisplayPort IPS LED Monitor
Quicklinx: 8PWWWS00
Mfr#: 860-10202
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 6ms
Speakers: [N/A]
Interfaces: Mini DisplayPort
More than 50 in stock
£293.85
Essential accessories
Experience the technology with the Dell UltraSharp U2413 24" high-performance monitor for consistent colors right out of the box. U2413 with PremierColor comes factory color calibrated to support 99% AdobeRGB which enables brilliant and accurate color hues and saturation. Six axis color control enables further user customization, professional color critical work.
Dell UltraSharp U2413 - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class C
Energy Consumption per Year
59 kWh
Power Consumption (On mode)
40 W
Built-in Devices
Card reader, USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
350 cd/m2
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
55.6 cm x 20.05 cm x 41.59 cm - with stand
7.32 kg
United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified , EPEAT Gold
TCO Displays
3 years warranty
Display Type
Energy Class
Class C
59 kWh
40 W
Diagonal Size
24"
Viewable Size
24"
Built-in Devices
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
350 cd/m2
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, PremierColor technology, 100% sRGB colour gamut, 99% Adobe RGB colour gamut, PowerNap, 120% (CIE 1976) colour gamut
7.32 kg
DVI-D ( HDCP ) , DisplayPort , Mini DisplayPort , HDMI , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
Flat Panel Mount Interface
Integrated cable management, 2 security lock slots (cable lock sold separately)
Stand
1 x DVI cable , 1 x DisplayPort cable , 1 x USB cable
TCO Displays
United Kingdom
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
60 Watt
On / Off Switch
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 55.6 cm - depth: 20.05 cm - height: 41.59 cm - weight: 7.32 kg , Without stand - width: 55.6 cm - depth: 6.71 cm - height: 36.16 cm - weight: 5.01 kg
EPEAT Compliant
EPEAT Gold
3 years warranty
Service & Support Details
Limited warranty - express exchange - 3 years - response time: next business day
10 - 80% (non-condensing)
Dell UltraSharp U2413 24 Bundle deal on Dell UltraSharp U2413 24" 1920x1200 6ms DVI-D HDMI DisplayPort IPS LED Monitor
£395.14
saving £9.99
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£303.84
8PWW C2G 0.5m Select High Speed HDMI with Ethernet In Stock £7.28
8PWW C2G 5m Select High Speed HDMI with Ethernet In Stock £21.50
8PWW C2G 10m Select High Speed HDMI with Ethernet In Stock £39.78
8PWW C2G 15m Select High Speed HDMI with Ethernet In Stock £56.40
Diagonal Size: 24in
Response Time: 6ms
Speakers: [N/A]
Brand: Dell
Price Range Inc VAT: 150 - 300
