BT.com
Wishlist
Dell UltraSharp U2412M 24" 1920x1200 8ms VGA DVI-D DisplayPort IPS LED Monitor
Delivery
Standard Due date unavailable
Enjoy widescreen performance, any way you want it. With a 24" 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style.
Dell UltraSharp U2412M - LED monitor - 24"
LED-backlit LCD monitor - 24"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Silver
55.6 cm x 18 cm x 51.4 cm
6.2 kg
Israel
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
TCO Displays 5.2
3 years warranty
Display Type
Diagonal Size
24"
Viewable Size
24"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, colour temperature
UltraSharp, HDCP, 72% (CIE 1931) colour gamut, 82% (CIE 1976) colour gamut
Silver
55.6 cm x 18 cm x 51.4 cm - with stand
6.2 kg
VGA , DVI-D , DisplayPort , USB
Mechanical
Tilt Angle
-4/+21
Stand
TCO Displays 5.2
Israel
38 Watt
Power Consumption Stand by / Sleep
0.5 Watt
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years - pick-up and return
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£40.22
£24.72
£9.80
£20.37
£18.12
£13.87
Scroll to top
