Click to visit BT.com
BT.com
Wishlist
Dell UltraSharp U2212HM 21.5" IPS LED 1920x1080 VGA DVI DisplayPort Monitor
Quicklinx: 8PSHWS00
Mfr#: 861-10346
Essential accessories
This is what a stellar view looks like
See vivid imagery from almost any angle. The 21.5" (54.61cm) Dell UltraSharp U2212HM monitor with LED offers a brilliant view, rich colours and adjustable height options.
  • Lose yourself in the details: Enjoy 1920x1080 (max) HD resolution, a vivid 2,000,000:1 (typical) dynamic contrast ratio and IPS technology for outstanding colour consistency across a wide viewing range.
  • Stay comfortable and connected: Select your best view with a range of tilt, swivel, pivot and height options. Link to a range of devices with 4 USB ports, a DisplayPort, plus DVI and VGA connections.
  • Be environmentally-conscious: Beyond offering efficiency and vivid detail, this monitor also meets EPEAT® Gold standards and is ENERGY STAR® qualified.
Dell UltraSharp U2212HM - LED monitor - 21.5"
LED-backlit LCD monitor - 21.5"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080 at 60 Hz
Pixel Pitch
0.2475 mm
Brightness
250 cd/m2
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
51.3 cm x 5.95 cm x 30.45 cm - without stand
2.7 kg
United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
TCO Displays
1 year warranty
Display Type
Diagonal Size
21.5"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.2475 mm
Brightness
250 cd/m2
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, 82% (CIE 1976) colour gamut
2.7 kg
VGA , DVI-D , DisplayPort , USB 2.0 upstream ( Type B ) , 4 x USB 2.0 downstream
Mechanical
Tilt Angle
-4/+21
Height Adjustment
130 mm
Flat Panel Mount Interface
Security lock slot (cable lock sold separately), cable organizer, adjustable height
Stand
TCO Displays
United Kingdom
AC 120/230 V ( 50/60 Hz )
30 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 51.3 cm - depth: 18.33 cm - height: 35.56 cm , Without stand - width: 51.3 cm - depth: 5.95 cm - height: 30.45 cm - weight: 2.7 kg
1 year warranty
Service & Support Details
Limited warranty - 1 year - response time: next business day
10 - 80% (non-condensing)
