BT.com
Wishlist
Dell UltraSharp U2212HM 21.5" IPS LED 1920x1080 VGA DVI DisplayPort Monitor
Free delivery
Delivery
Standard Due date unavailable
This is what a stellar view looks like
See vivid imagery from almost any angle. The 21.5" (54.61cm) Dell UltraSharp U2212HM monitor with LED offers a brilliant view, rich colours and adjustable height options.
  • Lose yourself in the details: Enjoy 1920x1080 (max) HD resolution, a vivid 2,000,000:1 (typical) dynamic contrast ratio and IPS technology for outstanding colour consistency across a wide viewing range.
  • Stay comfortable and connected: Select your best view with a range of tilt, swivel, pivot and height options. Link to a range of devices with 4 USB ports, a DisplayPort, plus DVI and VGA connections.
  • Be environmentally-conscious: Beyond offering efficiency and vivid detail, this monitor also meets EPEAT® Gold standards and is ENERGY STAR® qualified.
Dell UltraSharp U2212HM - LED monitor - 21.5"
LED-backlit LCD monitor - 21.5"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.2475 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
51.3 cm x 5.95 cm x 30.45 cm
2.7 kg
United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
TCO Displays
1 year warranty
Display Type
Diagonal Size
21.5"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.2475 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, 82% (CIE 1976) colour gamut
51.3 cm x 5.95 cm x 30.45 cm - without stand
2.7 kg
VGA , DVI-D , DisplayPort , USB 2.0 upstream (Type B) , 4 x USB 2.0 downstream
Mechanical
Tilt Angle
-4/+21
Height Adjustment
130 mm
Flat Panel Mount Interface
Security lock slot (cable lock sold separately), cable organizer, adjustable height
Stand
TCO Displays
United Kingdom
30 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 51.3 cm - depth: 18.33 cm - height: 35.56 cm , Without stand - width: 51.3 cm - depth: 5.95 cm - height: 30.45 cm - weight: 2.7 kg
Limited warranty - 1 year - response time: next business day
10 - 80% (non-condensing)
Scroll to top
