BT.com
Wishlist
Dell UltraSharp 27" UP2715K 3840x2160 8ms DP USB LED 5K Monitor
Delivery
Standard Due date unavailable
Welcome to the amazing sharpness and clarity of a 5K monitor. The Dell UltraSharp 27 Ultra HD 5K monitor - UP2715K features an astoundingly vivid Ultra HD resolution. That's a dramatic increase in screen clarity, with more pixels - or four times the content of QHD resolution, seven times the content of Full HD displays and almost double the number of pixels in an Ultra HD 4K monitor. The result is a breakthrough visual experience that brings outstanding realism, depth and crispness to pictures and movies.
Dell UltraSharp UP2715K - LED monitor - 27"
LED-backlit LCD monitor - 27"
Card reader, USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
5K Ultra HD (2880p) 5120 x 2880 at 60 Hz
Pixel Pitch
0.116 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xDisplayPort, Mini DisplayPort
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-reflective, anti-smudge coating
63.73 cm x 20.45 cm x 42.76 cm
9.38 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VESA EDID, DDC/CI, RoHS, NFPA 99, TCO Displays
Display Type
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.116 mm
Pixel Per Inch
218
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
30 - 60 Hz
Horizontal Refresh Rate
31 - 180 kHz
Video Bandwidth
483.3 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 10000K
Controls & Adjustments
Volume, brightness, contrast, sharpness, saturation, gamma correction, rotation, input select, colour temperature, hue, aspect control, colour space, gain, offset
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
PremierColor technology, LED edgelight system, 100% sRGB colour gamut, 99% Adobe RGB colour gamut, stand lock, Dell Custom Color, BFR/PVC-free, Energy Gauge, Mercury free, Factory Calibration, 6-axis colour adjustment, High Bit Rate 2 (HBR2)
63.73 cm x 20.45 cm x 42.76 cm - with stand
9.38 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
16 Watt
2 x DisplayPort , Mini DisplayPort , USB 3.0 upstream , 5 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
115 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, 1 USB 3.0 charging port, Harman Kardon speakers
Stand, cleaning cloth, cable management cover
2 x DisplayPort cable - 1.8 m , 2 x Mini DisplayPort-DisplayPort cable - 1.8 m , 1 x Mini DisplayPort cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
Power Supply
Internal
170 Watt
Power Consumption Stand by
1.2 Watt
Power Consumption Sleep
1.2 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 63.73 cm - depth: 20.45 cm - height: 42.76 cm - weight: 9.38 kg , Without stand - width: 63.73 cm - depth: 4.79 cm - height: 38.46 cm - weight: 7.14 kg
ENERGY STAR Certified
35 °C
10 - 80% (non-condensing)
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£39.98
£24.58
£9.80
£18.00
£13.78
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Only for Young eyes
Reviewed by doug on 29/03/2015
Getting a 4k (3840x2160) screen is great for young eyes, but is it usable for the rest of us. It is serious eye straight is you are using an application designed for a 1k screen and you view it on one of these. Using and IDE like Visual Studio is excellent on this, but not at the expense of getting a dual screen set up of 2 2k screens. In windows you can tell the 4k screen to behave as a 2k screen by stretching the desktop, but it looks a bit weird. If your Development team is under 30 and don't have glasses, they will love this.
Scroll to top
