BT.com
Wishlist
Dell U3014 30" 2560x1600 VGA DVI DP HDMI USB LED Monitor
Delivery
Standard Due date unavailable
Create precision work with the high-performance Dell UltraSharp U3014 monitor offering wide-ranging flexibility, efficiency and factory calibration. Designers, CGI animators, engineers, programmers, photographers and power users across many industries can benefit from high-end capabilities offered by the Dell UltraSharp U3014.
Connect to your external media with the flexible Dell UltraSharp U3014 monitor. This monitor offers multiple connectivity possibilities, mounting options and color settings, including daisy-chain connectivity for easy connections to multiple monitors.
Reduce the amount of time spent adjusting your screen and switching between applications with the enhanced capabilities of Dell Display Manager. This software application can help you get the most from your Dell UltraSharp monitor through Smart Video Enhance, Auto Mode and Easy Arrange functionalities.
You can help reduce energy costs and your impact on the environment with the Dell UltraSharp U3014 monitor. You also get the added benefit of PowerNap and Dynamic Dimming to help further reduce energy consumption.
Dell UltraSharp U3014 - LED monitor - 30"
LED-backlit LCD monitor - 30"
Energy Class
Class C
Energy Consumption per Year
82 kWh
Power Consumption (On mode)
56 W
Card reader, USB 3.0 hub
Aspect Ratio
16:10
Native Resolution
2560 x 1600 at 60 Hz
Pixel Pitch
0.25 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
6 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, DisplayPort, Mini DisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
68.97 cm x 20.14 cm x 57.27 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
EMC, CECP, TCO Displays
3 years warranty
Display Type
Energy Class
Class C
82 kWh
56 W
Diagonal Size
30"
Viewable Size
29.77"
Built-in Devices
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.25 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, PremierColor technology, PowerNap, Dynamic Dimming, 120% (CIE 1976) colour gamut
68.97 cm x 20.14 cm x 57.27 cm - with stand
DVI-D (dual link) (HDCP) , DisplayPort , Mini DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream , HDMI , Audio line-out
Mechanical
Flat Panel Mount Interface
Security lock slot (cable lock sold separately), integrated cable management
Stand, cable tie
1 x USB cable , 1 x DVI cable , 1 x DisplayPort cable
Power Supply
Internal
60 Watt
Power Consumption Stand by
0.98 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Included Software
Drivers & Utilities
Dimensions & Weight Details
Without stand - width: 68.97 cm - depth: 6.1 cm - height: 44.92 cm - weight: 7.35 kg , With stand - width: 68.97 cm - depth: 20.14 cm - height: 57.27 cm
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Accessories
£9.99
£7.15
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£19.86
£38.52
£52.15
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£59.19
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Good
Reviewed by Loggy on 17/05/2014
Upgraded from my Iyama 27" 19x12, I just wanted more screen estate but as there are no lower res big screens I had to go with this. I was a bit worried about my single evga GTX 690 not being enough to power this 2560 1600 resolution but its more than powerful enough for the job. Grid 2- Dirt 3- Cod fps's, all my old games look 'bigger' and run very well,its great, max res all fine. The viewable screen measures 64 x 40 cm which is BIG ! No latency from my i7 975 extreme system. All the text and icons and windows 7 stuff can be resized to your requirements. You must use the fat DVI cable provided to get the best screen text, I used my old DVI cable and the windows screen text was unreadable, I googled and found the fat cable tip. The dell software is superb and lets you set different brightness, contrast, colour, and processing modes for the different windows and applications actions which switch on the fly, I have a dull desktop but set brighter or warmer etc modes for different task.
Scroll to top
