BT.com
Wishlist
Dell U2913WM 29" 2560x1080 VGA DVI DP HDMI USB LED Monitor
Delivery
Standard Due date unavailable
Experience the panoramic 29" Dell UltraSharp U2913WM, featuring 2560 x 1080 Full HD, versatile connectivity and innovative productivity features. Navigate multiple applications at once and multitask like never before. A vast, 29" panoramic display with 21:9 aspect ratio and 2560 x 1080 Full HD offers the screen space of side-by-side monitors without a distracting bezel in between. Plus, with a 178-degree/178-degree ultra-wide viewing angle, you can enjoy an excellent view from almost any position.
Dell UltraSharp U2913WM - LED monitor - 29"
LED-backlit LCD monitor - 29"
Energy Class
Class B
Energy Consumption per Year
47 kWh
Power Consumption (On mode)
32 W
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
Full HD 2560 x 1080 at 60 Hz
Pixel Pitch
0.09 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort, Mini DisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
69.98 cm x 19.42 cm x 35.87 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
3 years warranty
Display Type
Energy Class
Class B
47 kWh
32 W
Diagonal Size
29"
Viewable Size
29"
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.09 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, 82% (CIE 1976) colour gamut, 99% sRGB colour gamut, integrated cable management
69.98 cm x 19.42 cm x 35.87 cm - with stand
DVI-D (dual link) (HDCP) , DisplayPort , Mini DisplayPort , HDMI , VGA , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out , DisplayPort output
Mechanical
Height Adjustment
130 mm
Flat Panel Mount Interface
Security lock slot (cable lock sold separately), anti-theft ring, integrated cable management
Cable tie
1 x DVI cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable
Power Supply
Internal
32 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Included Software
Driver
Dimensions & Weight Details
With stand - width: 69.98 cm - depth: 19.42 cm - height: 35.87 cm , Without stand - width: 69.98 cm - depth: 6.12 cm - height: 31.7 cm - weight: 5.76 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
Scroll to top
