BT.com
Wishlist
Dell U2715H 27" IPS HDMI Display Port LED Monitor
Delivery
Standard Due date unavailable
Superior screen resolution and real estate for a view you can't wait to get your eyes on. Work the way you want. Position your monitor for ultimate comfort with a full range of tilt, pivot, swivel and height adjustments along with easy connections to your PC and peripherals. Your Dell UltraSharp 27 monitor - U2715H is designed to be pixel perfect. Complete your Dell monitor experience. Your Dell UltraSharp 27 monitor - U2715H is just the start. Look for these great accessories when finalizing your purchase.
Dell UltraSharp U2715H - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
48 kWh
Power Consumption (On mode)
33 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.8 million colours
Input Connectors
2xHDMI, 2xMHL, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
61.27 cm x 20.5 cm x 40.99 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC, DDC/CI, RoHS, NFPA 99, TCO Displays
3 years warranty
Display Type
Energy Class
Class B
48 kWh
33 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
56 - 86 Hz
Horizontal Refresh Rate
30 - 113 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 5000K, 6500K, 7500K, 10000K, 5700K
Controls & Adjustments
Brightness, contrast, sharpness, saturation, input select, colour temperature, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
LED edgelight system, stand lock, 99% sRGB colour gamut, BFR/PVC-free, Energy Gauge, Energy Saver, Premium Panel Guarantee, 91% (CIE 1976) colour gamut, 76% (CIE 1931) colour gamut
61.27 cm x 20.5 cm x 40.99 cm - with stand
2 x MHL / HDMI , DisplayPort output (MST) , Mini DisplayPort , 5 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out , DisplayPort
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
115 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
Stand
Power Supply
Internal
88 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 61.27 cm - depth: 20.5 cm - height: 40.99 cm , Without stand - width: 61.27 cm - depth: 4.64 cm - height: 36.34 cm - weight: 4.91 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Scroll to top
