BT.com
Wishlist
Dell Sliding Rails Without Cable Management
Dell Sliding Rails Without Cable...
£90.87
£90.87
Add to wishlist
Delivery
Standard Due date unavailable
Dell ReadyRails Sliding Rails without Cable Management Arm. Rack slide rail kit for PowerEdge T320, T420, T430
Dell ReadyRails Sliding Rails without Cable Management Arm - rack slide rail kit
Rack slide rail kit
Rack slide rail kit
Dell PowerEdge T320, T420, T430
Buy used stock
What is used stock?
Item condition Customer return - item has been opened but is in excellent condition
Ref: DFFX 038597
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£12.00
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
