BT.com
Wishlist
Dell S560T 1080p DLP 3400 ANSI Interactive Projector
Dell S560T 1080p DLP 3400 ANSI...
£1,418.07
£1,418.07
Add to wishlist
Delivery
Standard Due date unavailable
From classrooms to conference rooms, the S560T offers versatility and user-friendly features so you can keep audiences enthralled and interacting.
Fast setup, user-friendly compatibility, and wireless options make it easy to connect and start projecting from different devices.
Engage audiences with multi-touch, interactive presentations in Full HD resolution, ideal for group collaboration.
What's in the box
  • Dell S560T
  • Remote control, touch unit, 2 x passive pens, touch unit base plate kit
  • VGA cable - 5 m
  • Mini-USB to USB cable - 5 m
Dell S560T - DLP projector
DLP projector - 1080p
Microdisplay
DarkChip 3
Brightness
3400 ANSI lumens
Contrast Ratio
1800:1
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
260 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
Video Input
RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, PAL 60, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
320 Watt
38.3 cm x 31.8 cm x 10.3 cm
4.7 kg
Projector
Microdisplay
DarkChip 3
Brightness
3400 ANSI lumens
Contrast Ratio
1800:1
Image Size
206 cm - 254 cm
Projection Distance
0.446 m - 0.558 m
Throw Ratio
0.25:1
Resolution
Native Aspect Ratio
16:9
Colour Support
Bulb type
260 Watt
Bulb life cycle
Video Input
TV System
Analogue video Signal
Video Interfaces
HDMI, composite video, RGB
Video Modes
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x HDMI input - 19 pin HDMI Type A , 1 x USB - mini-USB Type B , 1 x USB - 4 pin USB Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 2 x audio line-out - RCA x 2 , 1 x audio line-out - mini-phone mono 3.5 mm , 1 x microphone - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
1 x VGA cable - 5 m , 1 x mini-USB to USB cable - 5 m
Power Source
AC
Nominal Voltage
320 Watt
Power Consumption Stand by
0.5 Watt
38.3 cm
31.8 cm
10.3 cm
4.7 kg
5 °C
0 - 80%
Sound Emission
36 dBA
32 dBA
Scroll to top
